public VersionManager GetVersionManager()
Public Function GetVersionManager() As VersionManager
Return Value
The VersionManager associated with this geodatabase if it supports versioning.
| Exception | Description |
| System.InvalidOperationException | This geodatabase does not support versioning. |
Task GetVersionConflictsInfoInUpdateDeleteTypeAsync(
ServiceConnectionProperties featureServiceConnectionProperties,
string featureClassName) => QueuedTask.Run(() =>
// To illustrate the conflict between versions,
// the feature is updated in the child version and deleted in the parent version.
long featureObjectIDForEdit = Int64.MinValue;
// Get branch versioned service
using (Geodatabase fsGeodatabase = new Geodatabase(featureServiceConnectionProperties))
using (VersionManager versionManager = fsGeodatabase.GetVersionManager())
using (Version defaultVersion = versionManager.GetDefaultVersion())
using (Geodatabase defaultGeodatabase = defaultVersion.Connect())
using (FeatureClass defaultFeatureClass = defaultGeodatabase.OpenDataset<FeatureClass>(featureClassName))
using (FeatureClassDefinition defaultFeatureClassDefinition = defaultFeatureClass.GetDefinition())
// Create a feature in the default version to edit in a branch
defaultGeodatabase.ApplyEdits(() =>
using (RowBuffer rowBuffer = defaultFeatureClass.CreateRowBuffer())
rowBuffer["NAME"] = "Loblolly Pine";
rowBuffer["TREEAGE"] = 1;
rowBuffer[defaultFeatureClassDefinition.GetShapeField()] = new MapPointBuilderEx(new Coordinate2D(1, 1),
SpatialReferenceBuilder.CreateSpatialReference(4152, 0)).ToGeometry();
using (Feature feature = defaultFeatureClass.CreateRow(rowBuffer))
featureObjectIDForEdit = feature.GetObjectID();
// Add newly created feature in the filter
QueryFilter queryFilter = new QueryFilter { ObjectIDs = new List<long> { featureObjectIDForEdit } };
// Create a branch version
VersionDescription versionDescription = new VersionDescription("UpdateDeleteConflictType",
"Update-Delete version conflict type", VersionAccessType.Public);
// Edit the feature in the branch
using (Version editVersion = versionManager.CreateVersion(versionDescription))
using (Geodatabase branchGeodatabase = editVersion.Connect())
using (FeatureClass featureClass = branchGeodatabase.OpenDataset<FeatureClass>(featureClassName))
using (RowCursor rowCursor = featureClass.Search(queryFilter, false))
branchGeodatabase.ApplyEdits(() =>
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
row["TREEAGE"] = 100;
row["NAME"] = $"{row["Name"]}_EditInBranch";
row.Store();
// Delete the feature from the default version
defaultFeatureClass.DeleteRows(queryFilter);
// Reconcile options
ReconcileOptions reconcileOptions = new ReconcileOptions(defaultVersion)
ConflictResolutionType = ConflictResolutionType.FavorEditVersion,
ConflictDetectionType = ConflictDetectionType.ByRow,
ConflictResolutionMethod = ConflictResolutionMethod.Continue
// Reconcile with default
ReconcileResult reconcileResult = editVersion.Reconcile(reconcileOptions);
// Check for conflicts
bool hasConflictsReconcileResults = reconcileResult.HasConflicts;
bool hasConflictsAfterReconcile = editVersion.HasConflicts();
// Fetch conflicts
IReadOnlyList<Conflict> conflictsAfterReconcile = editVersion.GetConflicts();
// Iterate conflicts
foreach (Conflict conflict in conflictsAfterReconcile)
// Object ID of row where conflict occurs
long objectId = conflict.ObjectID;
ConflictType conflictType = conflict.ConflictType;
IReadOnlyList<FieldValue> ancestorVersionValues = conflict.AncestorVersionValues;
object nameAncestor = ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
object treeAgeAncestor =
ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
IReadOnlyList<FieldValue> childVersionValues = conflict.ChildVersionValues;
object nameChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
object treeAgeChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
IReadOnlyList<FieldValue> parentVersionValues = conflict.ParentVersionValues;
IReadOnlyList<Field> originalFields = defaultFeatureClassDefinition.GetFields();
string datasetName = conflict.DatasetName;
Task<Geodatabase> ConnectToVersionAsync(Geodatabase geodatabase, string versionName) => QueuedTask.Run(() =>
Geodatabase connectedVersion = null;
if (geodatabase.IsVersioningSupported())
using (VersionManager versionManager = geodatabase.GetVersionManager())
using (Version version = versionManager.GetVersion(versionName))
connectedVersion = version.Connect();
return connectedVersion;
Task ReconcileAndPostAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
// Get a reference to our version and our parent
using (Version currentVersion = versionManager.GetCurrentVersion())
using (Version parentVersion = currentVersion.GetParent())
// Create a ReconcileOptions object
ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
if (!reconcileResult.HasConflicts)
//No conflicts, perform the post
PostOptions postOptions = new PostOptions(parentVersion);
//var postOptions = new PostOptions(); for default version
postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
// Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
// currentVersion.Post(postOptions);
currentVersion.Reconcile(reconcileOptions, postOptions);
Task ReconcileAndPost2Async(Geodatabase geodatabase) => QueuedTask.Run(() =>
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions, postOptions);
if (reconcileResult.HasConflicts)
//TODO resolve conflicts
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
Version defaultVersion = versionManager.GetDefaultVersion();
string testVersionName = versionNames.First(v => v.Contains("Test"));
Version testVersion = versionManager.GetVersion(testVersionName);
Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
Geodatabase qaVersionGeodatabase = qaVersion.Connect();
FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
Task<Version> FindDefaultVersionAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
if (!geodatabase.IsVersioningSupported())
return null;
Version currentVersion = versionManager.GetCurrentVersion();
Version defaultVersion = GetDefaultVersion(currentVersion);
if (currentVersion != defaultVersion)
currentVersion.Dispose(); // If we are not pointing to default, we want to dispose this Version object
return defaultVersion;
// Check to see if the current version is default.
// Works with both branch and traditional versioning.
bool IsDefaultVersion(Version version)
Version parentVersion = version.GetParent();
if (parentVersion == null)
return true;
parentVersion.Dispose();
return false;
// Gets the default version.
// Note that this routine depends on IsDefaultVersion(), above.
Version GetDefaultVersion(Version version)
if (IsDefaultVersion(version))
return version;
Version parent = version.GetParent();
Version ancestor = GetDefaultVersion(parent);
if (parent != ancestor)
parent.Dispose(); //If the versioning tree is more than 2 deep, we want to dispose any intermediary versions
return ancestor;
Task<Version> CreateVersionAsync(Geodatabase geodatabase, string versionName, string description, VersionAccessType versionAccessType) => QueuedTask.Run(() =>
return null;
new VersionDescription(versionName, description, versionAccessType);
return versionManager.CreateVersion(versionDescription);
Task<HistoricalVersion> CreateHistoricalVersionAsync(Geodatabase geodatabase, string versionName) => QueuedTask.Run(() =>
HistoricalVersionDescription historicalVersionDescription =
new HistoricalVersionDescription(versionName, DateTime.Now);
HistoricalVersion historicalVersion =
versionManager.CreateHistoricalVersion(historicalVersionDescription);
return historicalVersion;
Task ChangeVersionsAsync(Geodatabase geodatabase, string toVersionName)
var map = MapView.Active?.Map;
if (map == null)
return Task.CompletedTask;
return QueuedTask.Run(() =>
VersionBaseType versionBaseType = versionManager.GetCurrentVersionBaseType();
if (versionBaseType == VersionBaseType.Version)
Version fromVersion = versionManager.GetCurrentVersion();
Version toVersion = versionManager.GetVersion(toVersionName);
// Switch between versions
map.ChangeVersion(fromVersion, toVersion);
if (versionBaseType == VersionBaseType.HistoricalVersion)
HistoricalVersion fromHistoricalVersion = versionManager.GetCurrentHistoricalVersion();
HistoricalVersion toHistoricalVersion = versionManager.GetHistoricalVersion(toVersionName);
// Switch between historical versions
map.ChangeVersion(fromHistoricalVersion, toHistoricalVersion);
// Switch from HistoricalVersion to Version and vice-versa
// map.ChangeVersion(fromHistoricalVersion, toVersion);
// map.ChangeVersion(fromVersion, toHistoricalVersion);
