ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / CreateEnvelope Method / CreateEnvelope(Coordinate2D,Coordinate2D,SpatialReference) Method
Lower left corner of the envelope.
Upper right corner of the envelope.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a new instance of the Envelope class.
    Syntax
    Public Overloads Shared Function CreateEnvelope( _
       ByVal minCoord As Coordinate2D, _
       ByVal maxCoord As Coordinate2D, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Envelope
    Parameters
    minCoord
    maxCoord
    spatialReference
    Return Value
    Remarks
    The resulting envelope is normalized to ensure its XMin <= XMax, YMin <= YMax. If any of the xy-coordinate values are NaN, then the envelope is set to empty.
    Example
    Create Projection Transformation
      // methods need to be on the MCT
      await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        SpatialReference sr4267 = SpatialReferenceBuilder.CreateSpatialReference(4267);
        SpatialReference sr4326 = SpatialReferences.WGS84;
        SpatialReference sr3857 = SpatialReferences.WebMercator;
        // Create transformation from  4267 -> 3857
        ProjectionTransformation projTransFromSRs =
             ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr4267, sr3857);
        // create an envelope
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(
                   new Coordinate2D(2, 2), new Coordinate2D(3, 3), sr4267);
        // Project with one geo transform 4267 -> 3857
        Envelope projectedEnvEx = GeometryEngine.Instance.ProjectEx(
                                       env, projTransFromSRs) as Envelope;
        // Create inverse transformation, 3857 -> 4267
        ProjectionTransformation projTransFromSRsInverse =
            ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr3857, sr4267);
        // Project the projected envelope back using the inverse transformation
        Envelope projectedEnvBack =
                 projectedEnvEx, projTransFromSRsInverse) as Envelope;
        bool isEqual = env.IsEqual(projectedEnvBack);
    Create Rectangle Element
      await QueuedTask.Run(() =>
      //Build geometry
      Coordinate2D ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D ur = new Coordinate2D(3.0, 5.75);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      var ge = GraphicFactory.Instance.CreateSimpleGraphic(env, polySym);
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45.0,
        CornerRounding = 5.0
      ElementFactory.Instance.CreateGraphicElement(
        layout, env, polySym, "New Rectangle", false, elemInfo);
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Intersection between two Polygons
      // determine intersection between two polygons
      Envelope env1 = EnvelopeBuilderEx.CreateEnvelope(new Coordinate2D(3.0, 2.0), new Coordinate2D(6.0, 6.0));
      Polygon poly1 = PolygonBuilderEx.CreatePolygon(env1);
      Envelope env2 = EnvelopeBuilderEx.CreateEnvelope(new Coordinate2D(1.0, 1.0), new Coordinate2D(4.0, 4.0));
      Polygon poly2 = PolygonBuilderEx.CreatePolygon(env2);
      Polygon polyResult = GeometryEngine.Instance.Intersection(poly1, poly2) as Polygon;
    Create Map Frame and Set Camera
      //Create a map frame and set its camera by zooming to the extent of an existing bookmark.
      var project = Project.Current;
      Coordinate2D mf_ll = new Coordinate2D(6.0, 8.5);
      Coordinate2D mf_ur = new Coordinate2D(8.0, 10.5);
      Envelope mf_env = EnvelopeBuilderEx.CreateEnvelope(mf_ll, mf_ur);
      //Reference map, create MF and add to layout
      MapProjectItem mapPrjItem = project.GetItems<MapProjectItem>()
                           .FirstOrDefault(item => item.Name.Equals("Map"));
      Map mfMap = mapPrjItem.GetMap();
      Bookmark bookmark = mfMap.GetBookmarks().FirstOrDefault(
                            b => b.Name == "Great Lakes");
      MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(
                           layout, mf_env, mfMap, "New Map Frame");
      //Zoom to bookmark
      mfElm.SetCamera(bookmark);
    Requirements
