ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / CreateEnvelope Method / CreateEnvelope(Envelope,SpatialReference) Method
The Envelope that will be copied.
(Optional) The SpatialReference. The default value is null. If spatialReference is null, then the spatial reference is inherited from envelope.
Example
    Convenience method to create a new instance of the Envelope class.
    Syntax
    public static Envelope CreateEnvelope(
       Envelope envelope,
       SpatialReference spatialReference
    Public Overloads Shared Function CreateEnvelope( _
       ByVal envelope As Envelope, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Envelope
    Parameters
    envelope
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    envelope is null.
    Remarks
    The resulting envelope inherits attributes, Z, M and ID-values, from the input envelope.
    Example
    Create Map Frame and Set Camera
      //Create a map frame and set its camera by zooming to the extent of an existing bookmark.
      var project = Project.Current;
      await QueuedTask.Run(() =>
      //Build 2D envelope geometry
      Coordinate2D mf_ll = new Coordinate2D(6.0, 8.5);
      Coordinate2D mf_ur = new Coordinate2D(8.0, 10.5);
      Envelope mf_env = EnvelopeBuilderEx.CreateEnvelope(mf_ll, mf_ur);
      //Reference map, create MF and add to layout
      MapProjectItem mapPrjItem = project.GetItems<MapProjectItem>()
                           .FirstOrDefault(item => item.Name.Equals("Map"));
      Map mfMap = mapPrjItem.GetMap();
      Bookmark bookmark = mfMap.GetBookmarks().FirstOrDefault(
                            b => b.Name == "Great Lakes");
      MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(
                           layout, mf_env, mfMap, "New Map Frame");
      //Zoom to bookmark
      mfElm.SetCamera(bookmark);
    Requirements
