ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / CreateMapPoint Method / CreateMapPoint(SpatialReference) Method
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a MapPoint instance. The new instance is empty.
    Syntax
    public static MapPoint CreateMapPoint(
       SpatialReference spatialReference
    Public Overloads Shared Function CreateMapPoint( _
       Optional ByVal spatialReference As SpatialReference _
    ) As MapPoint
    Parameters
    spatialReference
    Return Value
    Example
    MapPoint - GeoCoordinateString Conversion
      SpatialReference sr = SpatialReferences.WGS84;
      SpatialReference sr2 = SpatialReferences.WebMercator;
      // create some points
      MapPoint point0 = MapPointBuilderEx.CreateMapPoint(0, 0, sr);
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(10, 20, sr);
      MapPoint point2 = GeometryEngine.Instance.Project(point1, sr2) as MapPoint;
      MapPoint pointEmpty = MapPointBuilderEx.CreateMapPoint(sr);
      MapPoint pointwithNoSR = MapPointBuilderEx.CreateMapPoint(1, 1);
      MapPoint pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, sr);
      // convert to MGRS
      ToGeoCoordinateParameter mgrsParam =
               new ToGeoCoordinateParameter(GeoCoordinateType.MGRS);
      // 31NAA6602100000
      string geoCoordString = point0.ToGeoCoordinateString(mgrsParam);
      // use the builder to create a new point from the string.
      // Coordinates are the same
      // outPoint.x = 0; outPoint.Y = 0
      MapPoint outPoint =
            MapPointBuilderEx.FromGeoCoordinateString(
                      geoCoordString, sr, GeoCoordinateType.MGRS);
      // 32QPH0460911794
      // outPoint.X = 10; outPoint.Y = 20
      geoCoordString = point1.ToGeoCoordinateString(mgrsParam);
      outPoint = MapPointBuilderEx.FromGeoCoordinateString(
      // z, m are not transformed
      // outPoint.X = 1; outPoint.Y = 2; outPoint.Z = Nan; outPoint.M = Nan;
      geoCoordString = pointZM.ToGeoCoordinateString(mgrsParam);
      // set the number of digits to 2 and convert
      // 32QPH0512
      mgrsParam.NumDigits = 2;
      // convert to UTM
      ToGeoCoordinateParameter utmParam =
           new ToGeoCoordinateParameter(GeoCoordinateType.UTM);
      // 31N 166021 0000000
      geoCoordString = point0.ToGeoCoordinateString(utmParam);
      // 32Q 604609 2211793
      geoCoordString = point1.ToGeoCoordinateString(utmParam);
      // convert to DMS
      ToGeoCoordinateParameter dmsParam =
        new ToGeoCoordinateParameter(GeoCoordinateType.DMS);
      // 00 00 00.00N 000 00 00.00E
      geoCoordString = point0.ToGeoCoordinateString(dmsParam);
      // 20 00 00.00N 010 00 00.00E
      geoCoordString = point1.ToGeoCoordinateString(dmsParam);
      // convert to DDM
      ToGeoCoordinateParameter ddmParam =
        new ToGeoCoordinateParameter(GeoCoordinateType.DDM);
      // 00 00.0000N 000 00.0000E
      geoCoordString = point0.ToGeoCoordinateString(ddmParam);
      // 20 00.0000N 010 00.0000E
      geoCoordString = point1.ToGeoCoordinateString(ddmParam);
      // convert to DD
      ToGeoCoordinateParameter ddParam =
        new ToGeoCoordinateParameter(GeoCoordinateType.DD);
      // 00.000000N 000.000000E
      geoCoordString = point0.ToGeoCoordinateString(ddParam);
      // 20.000000N 010.000000E
      geoCoordString = point1.ToGeoCoordinateString(ddParam);
    Requirements
