ArcGIS.Desktop.Core Namespace / Favorite Class / IsAddedToAllNewProjects Property
Example
    Gets the flag indicating if the favorite is to be added to all new projects.
    Syntax
    public bool IsAddedToAllNewProjects {get;}
    Public ReadOnly Property IsAddedToAllNewProjects As Boolean
    Example
    Toggle the flag IsAddedToAllNewProjects for a favorite
      var newItemFolder = ItemFactory.Instance.Create(@"d:\data");
      // is the folder item already a favorite?
      var favorite = FavoritesManager.Current.GetFavorite(newItemFolder);
      if (favorite != null)
        if (favorite.IsAddedToAllNewProjects)
          FavoritesManager.Current.ClearIsAddedToAllNewProjects(favorite.Item);
        else
          FavoritesManager.Current.SetIsAddedToAllNewProjects(favorite.Item);
    Get the set of favorites and iterate
      var favorites = FavoritesManager.Current.GetFavorites();
      foreach (var favorite in favorites)
        bool isAddedToAllProjects = favorite.IsAddedToAllNewProjects;
        // retrieve the underlying item of the favorite
        Item item = favorite.Item;
        // Item properties
        var itemType = item.TypeID;
        var path = item.Path;
        // if it's a folder item
        if (item is FolderConnectionProjectItem)
        // if it's a geodatabase item
        else if (item is GDBProjectItem)
        // else
    Requirements
