ArcGIS.Desktop.Core Namespace / FavoritesManager Class / CanAddAsFavorite Method
The item to be checked to see if it's a favorite candidate.
Example
    Gets whether the item can be added to the favorites collection.
    Syntax
    public bool CanAddAsFavorite(
       Item item
    Public Function CanAddAsFavorite( _
       ByVal item As Item _
    ) As Boolean
    Parameters
    item
    Return Value
    True if the item can be made a favorite. False otherwise
    Example
    Add a Favorite - Folder
      var itemFolder = ItemFactory.Instance.Create(@"d:\data");
      // is the folder item already a favorite?
      var fav = FavoritesManager.Current.GetFavorite(itemFolder);
      if (fav == null)
        if (FavoritesManager.Current.CanAddAsFavorite(itemFolder))
          fav = FavoritesManager.Current.AddFavorite(itemFolder);
    Insert a Favorite - Geodatabase path
      gdbPath = "@C:\\myDataFolder\\myData.gdb";
      var itemGDB = ItemFactory.Instance.Create(gdbPath);
      // is the item already a favorite?
      var favorite = FavoritesManager.Current.GetFavorite(itemGDB);
      // no; add it with IsAddedToAllNewProjects set to true
      if (favorite != null)
        if (FavoritesManager.Current.CanAddAsFavorite(itemGDB))
          FavoritesManager.Current.InsertFavorite(itemGDB, 1, true);
    Add a Favorite - Style project item
      StyleProjectItem styleItem = Project.Current.GetItems<StyleProjectItem>().
                              FirstOrDefault(style => style.Name == "ArcGIS 3D");
      if (FavoritesManager.Current.CanAddAsFavorite(styleItem))
        // add to favorites with IsAddedToAllNewProjects set to false
        FavoritesManager.Current.AddFavorite(styleItem);
    Requirements
