public IReadOnlyList<KeyValuePair<string,List<long>>> Lines {get;}
Public ReadOnly Property Lines As IReadOnlyList(Of KeyValuePair(Of String,List(Of Long)))
string sReportResult = "Polygon Information --" + Environment.NewLine;
string sParcelTypeName = "tax";
string errorMessage = await QueuedTask.Run(async () =>
var myParcelFabricLayer =
activeMap.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
//if there is no fabric in the map then bail
if (myParcelFabricLayer == null)
return "There is no fabric layer in the map.";
//first get the parcel type feature layer
var parcelPolygonLayers = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(sParcelTypeName);
var featSrcLyr = parcelPolygonLayers.FirstOrDefault();
if (featSrcLyr.SelectionCount == 0)
return "There is no selection on the " + sParcelTypeName + " layer.";
sReportResult += " Parcel Type: " + sParcelTypeName + Environment.NewLine;
sReportResult += " Polygons: " + featSrcLyr.SelectionCount + Environment.NewLine + Environment.NewLine;
try
// ------- get the selected parcels ---------
var ids = new List<long>((featSrcLyr as FeatureLayer).GetSelection().GetObjectIDs());
var sourceParcels = new Dictionary<MapMember, List<long>>
{ featSrcLyr, ids }
ParcelFeatures parcFeatures =
await myParcelFabricLayer.GetParcelFeaturesAsync(SelectionSet.FromDictionary(sourceParcels));
//since we know that we want to report on Tax lines only, and for this functionality
// we can use any of the Tax line layer instances (if there happens to be more than one)
// we can get the first instance as follows
var parcelLineLayers = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(sParcelTypeName);
FeatureLayer myLineFeatureLyr = parcelLineLayers.FirstOrDefault();
if (myLineFeatureLyr == null)
return sParcelTypeName + " line layer not found";
var pointLayers = await myParcelFabricLayer.GetPointsLayerAsync();
FeatureLayer myPointFeatureLyr = pointLayers.FirstOrDefault();
if (myPointFeatureLyr == null)
return "fabric point layer not found";
var LineInfo = parcFeatures.Lines; //then get the line information from the parcel features object
//... and then do some work for each of the lines
int iRadiusAttributeCnt = 0;
int iDistanceAttributeCnt = 0;
sReportResult += "Line Information --";
foreach (KeyValuePair<string, List<long>> kvp in LineInfo)
if (!kvp.Key.Equals(sParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
continue; // ignore any other lines from different parcel types
foreach (long oid in kvp.Value)
var insp = myLineFeatureLyr.Inspect(oid);
var dRadius = insp["RADIUS"];
var dDistance = insp["DISTANCE"];
if (dRadius != DBNull.Value)
iRadiusAttributeCnt++;
if (dDistance != DBNull.Value)
iDistanceAttributeCnt++;
//Polyline poly = (Polyline)insp["SHAPE"];
sReportResult += Environment.NewLine + " Distance attributes: " + iDistanceAttributeCnt.ToString();
sReportResult += Environment.NewLine + " Radius attributes: " + iRadiusAttributeCnt.ToString();
var PointInfo = parcFeatures.Points; //get the point information from the parcel features object
//... and then do some work for each of the points
sReportResult += Environment.NewLine + Environment.NewLine + "Point Information --";
int iFixedPointCnt = 0;
int iNonFixedPointCnt = 0;
foreach (long oid in PointInfo)
var insp = myPointFeatureLyr.Inspect(oid);
var isFixed = insp["ISFIXED"];
if (isFixed == DBNull.Value || (int)isFixed == 0)
iNonFixedPointCnt++;
else
iFixedPointCnt++;
// var pt = insp["SHAPE"];
sReportResult += Environment.NewLine + " Fixed Points: " + iFixedPointCnt.ToString();
sReportResult += Environment.NewLine + " Non-Fixed Points: " + iNonFixedPointCnt.ToString();
catch (Exception ex)
return ex.Message;
return "";
if (!string.IsNullOrEmpty(errorMessage))
MessageBox.Show(errorMessage, "Get Parcel Features");
else
MessageBox.Show(sReportResult, "Get Parcel Features");
