ArcGIS.Desktop.Mapping.Offline Namespace / ExportTileCacheParams Class
Members Example
    Specifies the parameters for exporting raster or vector tile caches.
    Object Model
    ExportTileCacheParams ClassEnvelope Class
    Syntax
    public class ExportTileCacheParams
    Public Class ExportTileCacheParams
    Example
    Export Map Raster Tile Cache Content
      //Does the map have any exportable raster content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportRasterTileCache(map);
      var rasterTileExtent = MapView.Active.Extent;
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportRasterTileCacheScales(map, rasterTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = rasterTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale
          //DestinationFolder = .... (optional)
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportRasterTileCache(map, export_params);
    Export Map Vector Tile Cache Content
      var mapVectorTileExtent = MapView.Active.Extent;
      //Does the map have any exportable vector tile content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportVectorTileCache(map);
      if (canExport)
        var scales = GenerateOfflineMap.Instance.GetExportVectorTileCacheScales(map, mapVectorTileExtent);
          Extent = mapVectorTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale,
          DestinationFolder = @"C:\Data\Offline"
        GenerateOfflineMap.Instance.ExportVectorTileCache(map, export_params);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.Offline.ExportTileCacheParams
    Requirements
