//namespace ArcGIS.Desktop.Mapping.Offline
var extent = mapView.Extent;
await QueuedTask.Run(() =>
//Check map has sync-enabled content that can be taken offline
var hasSyncEnabledContent = GenerateOfflineMap.Instance.GetCanGenerateReplicas(map);
if (hasSyncEnabledContent)
//Generate Replicas and take the content offline
//sync-enabled content gets copied local into a SQLite DB
var gen_params = new GenerateReplicaParams()
Extent = extent, //SR of extent must match map SR
//DestinationFolder can be left blank, if specified,
//it must exist. Defaults to project offline maps location
DestinationFolder = @"C:\Data\Offline"
//Sync-enabled layer content will be resourced to point to the
//local replica content.
GenerateOfflineMap.Instance.GenerateReplicas(map, gen_params);
System.Object
ArcGIS.Desktop.Mapping.Offline.GenerateReplicaParams
