ArcGIS.Core.Geometry Namespace / LineBuilderEx Class / LineBuilderEx Constructor / LineBuilderEx Constructor(MapPoint,MapPoint,SpatialReference)
The start point.
The end point.
(Optional) The spatial reference. The default value is null. The spatial references of the start point and end point are ignored.
    Creates a new instance of the LineBuilderEx class defined from the start and end point.
    Syntax
    Public Function New( _
       ByVal startPoint As MapPoint, _
       ByVal endPoint As MapPoint, _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    startPoint
    The start point.
    endPoint
    The end point.
    spatialReference
    Exceptions
    ExceptionDescription
    startPoint or endPoint is null or empty.
    Remarks
    This is a straight line segment between the start and end point.
    Line Segment
    Requirements
