ArcGIS.Core.Geometry Namespace / LineBuilderEx Class / LineBuilderEx Constructor / LineBuilderEx Constructor(Coordinate3D,Coordinate3D,SpatialReference)
The start point.
The end point.
(Optional) The spatial reference. The default value is null.
    Creates a new instance of the LineBuilderEx class defined from the start and end point.
    Syntax
    Parameters
    startPoint
    The start point.
    endPoint
    The end point.
    spatialReference
    Exceptions
    ExceptionDescription
    startPoint or endPoint is empty.
    Remarks
    This is a straight line segment between the start and end point.
    Line Segment
    Requirements
