ArcGIS.Core.Geometry Namespace / LineBuilderEx Class / SetCoords Method
The start point.
The end point.
Example
    SetCoords Method (LineBuilderEx)
    Sets this builders start and end points to be startPoint and endPoint.
    Syntax
    public void SetCoords(
       MapPoint startPoint,
       MapPoint endPoint
    Public Sub SetCoords( _
       ByVal startPoint As MapPoint, _
       ByVal endPoint As MapPoint _
    Parameters
    startPoint
    The start point.
    endPoint
    The end point.
    Exceptions
    ExceptionDescription
    startPoint or endPoint is null.
    Remarks
    If the start point and end point are identical, it creates a zero length line with the same start and end point.
    Line Segment
    Example
    Alter LineSegment Coordinates
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(2.0, 1.0);
      // builderEx constructors don't need to run on the MCT
      LineBuilderEx lbuilderEx = new LineBuilderEx(lineSegment);
      // find the existing coordinates
      lbuilderEx.QueryCoords(out startPt, out endPt);
      // or use
      //startPt = lbuilderEx.StartPoint;
      //endPt = lbuilderEx.EndPoint;
      // update the coordinates
      lbuilderEx.SetCoords(GeometryEngine.Instance.Move(startPt, 10, 10) as MapPoint, GeometryEngine.Instance.Move(endPt, -10, -10) as MapPoint);
      // or use
      //lbuilderEx.StartPoint = GeometryEngine.Instance.Move(startPt, 10, 10) as MapPoint;
      //lbuilderEx.EndPoint = GeometryEngine.Instance.Move(endPt, -10, -10) as MapPoint;
      LineSegment segment2 = lbuilderEx.ToSegment() as LineSegment;
    Requirements
