ArcGIS.Core.Geometry Namespace / SegmentBuilderEx Class / EndPoint Property
Example
    EndPoint Property (SegmentBuilderEx)
    Gets or sets the end point.
    Syntax
    public virtual MapPoint EndPoint {get; set;}
    Public Overridable Property EndPoint As MapPoint
    Exceptions
    ExceptionDescription
    Setting the end point with a null object.
    Example
    Create 3D Polyline and set Z-values while preserving curve segments
      PolylineBuilderEx polylineBuilder = new PolylineBuilderEx(polyline);
      polylineBuilder.HasZ = true;
      // The HasZ property is set to true for all the points in
      // polyline3D when you call ToGeometry().
      Polyline polyline3D = polylineBuilder.ToGeometry();
      // For this example, create Z-values.
      // You may want to pass them in as a parameter.
      int numPoints = polyline3D.PointCount;
      double[] zValues = new double[numPoints];
      for (int i = 0; i < numPoints; i++)
        zValues[i] = i % 2 == 0 ? 2 : 1;
      // We need to know at which point index each part starts
      int partPointIndex = 0;
      int numParts = polyline3D.PartCount;
      for (int i = 0; i < numParts; i++)
        var part = polyline3D.Parts[i];
        int numSegmentsInPolyline3D = part.Count;
        for (int j = 0; j < numSegmentsInPolyline3D; j++)
          Segment segment = part[j];
          MapPointBuilderEx pointBuilder = new MapPointBuilderEx(segment.StartPoint);
          pointBuilder.Z = zValues[partPointIndex++];
          MapPoint startPoint = pointBuilder.ToGeometry();
          // Make sure that the end point of this segment is the same as the start point of the next segment
          pointBuilder = new MapPointBuilderEx(segment.EndPoint);
          pointBuilder.Z = zValues[partPointIndex];
          MapPoint endPoint = pointBuilder.ToGeometry();
          SegmentType segmentType = segment.SegmentType;
          SegmentBuilderEx segmentBuilder = null;
          switch (segmentType)
            case SegmentType.Line:
              segmentBuilder = new LineBuilderEx((LineSegment)segment);
              break;
            case SegmentType.Bezier:
              segmentBuilder = new CubicBezierBuilderEx((CubicBezierSegment)segment);
              break;
            case SegmentType.EllipticArc:
              segmentBuilder = new EllipticArcBuilderEx((EllipticArcSegment)segment);
              break;
          // Only change the start and end point which now have Z-values set.
          // This will preserve the curve if the segment is an EllipticArcSegment or CubicBezierSegment.
          segmentBuilder.StartPoint = startPoint;
          segmentBuilder.EndPoint = endPoint;
          segment = segmentBuilder.ToSegment();
          polylineBuilder.ReplaceSegment(i, j, segment);
        // Move point index for the next part
        partPointIndex++;
    Cubic Bezier Builder Properties
      // retrieve the bezier curve's control points
      CubicBezierBuilderEx cbbEx = new CubicBezierBuilderEx(bezierSegment);
      MapPoint startPtEx = cbbEx.StartPoint;
      Coordinate2D ctrlPt1Ex = cbbEx.ControlPoint1;
      Coordinate2D ctrlPt2Ex = cbbEx.ControlPoint2;
      MapPoint endPtEx = cbbEx.EndPoint;
      // or use the QueryCoords method
      cbbEx.QueryCoords(out startPtEx, out ctrlPt1Ex, out ctrlPt2Ex, out endPtEx);
    Requirements
