ArcGIS.Core.Data.Parcels Namespace / ParcelTypeInfo Class / PolygonFeatureTable Property
Example
    Gets the polygon feature table.
    Syntax
    Public ReadOnly Property PolygonFeatureTable As Table
    public Table PolygonFeatureTable {get;}
    Example
    Get parcel type feature classes from the parcel fabric dataset
      string errorMessage = await QueuedTask.Run(() =>
      try
        var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
        //if there is no fabric in the map then bail
        if (myParcelFabricLayer == null)
          return "There is no fabric in the map.";
        string myParcelTypeName = "Tax";
        var myParcelFabricDataset = myParcelFabricLayer.GetParcelFabric();
        var typeInfo = myParcelFabricDataset.GetParcelTypeInfo();
        FeatureClass lineFCType = null;
        FeatureClass polyFCType = null;
        foreach (var info in typeInfo)
          if (info.Name.Equals(myParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
            lineFCType = info.LineFeatureTable as FeatureClass;
            polyFCType = info.PolygonFeatureTable as FeatureClass;
            break;
      catch (Exception ex)
        return ex.Message;
      return "";
      if (!string.IsNullOrEmpty(errorMessage))
        MessageBox.Show(errorMessage, "Get Parcel Type feature classes.");
    Requirements
