ArcGIS.Desktop.Core Namespace / VertexMarkerType Enumeration
Example Example
    Defines the set of valid marker types used in vertex symbology.
    Syntax
    Members
    MemberDescription
    Circle Circle.
    CircleWithCenteredText Text within a circle.
    Cross Cross.
    Diamond Diamond.
    DiscoRectangle Disco hexagon.
    Hexagon Hexagon.
    PushPin Push pin.
    Rectangle Rectangle.
    Rod Rod.
    RodWithPerpendicularText Rod with perpendicular text.
    RoundedRectangle Rounded rectangle.
    RoundedSquare Rounded square.
    RoundedTriangle Rounded triangle.
    Square Square.
    Star Star.
    StretchedHexagon Stretched hexagon.
    Text Text.
    Triangle Triangle.
    Example
    Set Sketch Vertex Symbol Options
      var options = ApplicationOptions.EditingOptions;
      //var options = ApplicationOptions.EditingOptions;
      await QueuedTask.Run(() =>
        //change the regular unselected vertex symbol
        //default is a green, hollow, square, 5pts. Change to
        //Blue outline diamond, 10 pts
        var vertexSymbol = new VertexSymbolOptions(VertexSymbolType.RegularUnselected);
        vertexSymbol.OutlineColor = ColorFactory.Instance.BlueRGB;
        vertexSymbol.MarkerType = VertexMarkerType.Diamond;
        vertexSymbol.Size = 10;
        //Are these valid?
        if (options.CanSetVertexSymbolOptions(
             VertexSymbolType.RegularUnselected, vertexSymbol))
          //apply them
          options.SetVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexSymbol);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Core.VertexMarkerType
    Requirements
