ArcGIS.Desktop.Core Namespace / VertexSymbolType Enumeration
Example Example
    Defines the types of vertex symbols used while sketching.
    Syntax
    Members
    MemberDescription
    ControlpointSelected A control point that is selected.
    ControlpointUnselected A control point that is unselected.
    CurrentSelected A vertex that is the currently selected vertex.
    CurrentUnselected A vertex that is the current vertex that is unselected.
    RegularSelected A vertex that is selected.
    RegularUnselected A vertex that is unselected.
    Example
    Get Sketch Vertex Symbology Options
      var options = ApplicationOptions.EditingOptions;
      await QueuedTask.Run(() =>
        //There are 4 vertex symbol settings - selected, unselected and the
        //current vertex selected and unselected.
        var reg_select = options.GetVertexSymbolOptions(VertexSymbolType.RegularSelected);
        var reg_unsel = options.GetVertexSymbolOptions(VertexSymbolType.RegularUnselected);
        var curr_sel = options.GetVertexSymbolOptions(VertexSymbolType.CurrentSelected);
        var curr_unsel = options.GetVertexSymbolOptions(VertexSymbolType.CurrentUnselected);
        //to convert the options to a symbol use
        //GetPointSymbol
        var reg_sel_pt_symbol = reg_select.GetPointSymbol();
        //ditto for reg_unsel, curr_sel, curr_unsel
    Set Sketch Vertex Symbol Options
      //var options = ApplicationOptions.EditingOptions;
        //change the regular unselected vertex symbol
        //default is a green, hollow, square, 5pts. Change to
        //Blue outline diamond, 10 pts
        var vertexSymbol = new VertexSymbolOptions(VertexSymbolType.RegularUnselected);
        vertexSymbol.OutlineColor = ColorFactory.Instance.BlueRGB;
        vertexSymbol.MarkerType = VertexMarkerType.Diamond;
        vertexSymbol.Size = 10;
        //Are these valid?
        if (options.CanSetVertexSymbolOptions(
             VertexSymbolType.RegularUnselected, vertexSymbol))
          //apply them
          options.SetVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexSymbol);
    Set Sketch Vertex Symbol Back to Default
        //ditto for reg selected and current selected, unselected
        var def_reg_unsel =
          options.GetDefaultVertexSymbolOptions(VertexSymbolType.RegularUnselected);
        //apply default
          VertexSymbolType.RegularUnselected, def_reg_unsel);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Core.VertexSymbolType
    Requirements
