ArcGIS.Desktop.Core Namespace / DownloadOptions Class / AskForUnpackPPKXLocation Property
Example
    Gets and sets the 'Ask where to save before unpacking' option for project packages and templates.
    Syntax
    public bool AskForUnpackPPKXLocation {get; set;}
    Public Property AskForUnpackPPKXLocation As Boolean
    Remarks
    Setting this property to true automatically clears out the UnpackPPKXLocation property. This property is automatically set to false if the UnpackPPKXLocation property is set (via add-in or UI).
    Example
    Get DownloadOptions
      var staging = ApplicationOptions.DownloadOptions.StagingLocation;
      var ppkx_loc = ApplicationOptions.DownloadOptions.UnpackPPKXLocation;
      var ask_ppkx_loc = ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation;
      var other_loc = ApplicationOptions.DownloadOptions.UnpackOtherLocation;
      var ask_other_loc = ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation;
      var use_proj_folder = ApplicationOptions.DownloadOptions.UnpackOtherToProjectLocation;
      var offline_loc = ApplicationOptions.DownloadOptions.OfflineMapsLocation;
      var ask_offline_loc = ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation;
      var use_proj_folder_offline = ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation;
    Set DownloadOptions for PPKX
      //Options are mutually exclusive.
      //Setting ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation = true
      //supersedes any value in ApplicationOptions.DownloadOptions.UnpackPPKXLocation
      //and will prompt the user on an unpack. The value of
      //ApplicationOptions.DownloadOptions.UnpackPPKXLocation will be unaffected
      //and is ignored. This is the same behavior as on the Pro UI.
      ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation = true;//override location
      //The default location is typically <My Documents>\ArcGIS\Packages
      //Setting ApplicationOptions.DownloadOptions.UnpackPPKXLocation to any
      //location overrides ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation
      //and sets it to false. This is the same behavior as on the Pro UI.
      ApplicationOptions.DownloadOptions.UnpackPPKXLocation = @"D:\data\for_ppkx";
      //Or, if ApplicationOptions.DownloadOptions.UnpackPPKXLocation already
      //contains a valid path, set ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation
      //explicitly to false to use the UnpackPPKXLocation
      if (!string.IsNullOrEmpty(ApplicationOptions.DownloadOptions.UnpackPPKXLocation))
        ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation = false;
    Requirements
