ArcGIS.Desktop.Core Namespace / GeneralOptions Class / ProjectCreateInFolder Property
Example
    Gets and sets whether to store the project file, project geodatabase, and project toolbox in a folder named for the project.
    Syntax
    Public Property ProjectCreateInFolder As Boolean
    public bool ProjectCreateInFolder {get; set;}
    Remarks
    If ProjectCreateInFolder is set to true (the default), then a subfolder named for the project will be created (within whatever is the location being used for the new project). If ProjectCreateInFolder is set to false then project default files are stored in the default project location without organizing them into their own folder.
    Example
    Get GeneralOptions
      var startMode = ApplicationOptions.GeneralOptions.StartupOption;
      var aprx_path = ApplicationOptions.GeneralOptions.StartupProjectPath;
      var hf_option = ApplicationOptions.GeneralOptions.HomeFolderOption;
      var folder = ApplicationOptions.GeneralOptions.CustomHomeFolder;
      var gdb_option = ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption;
      var def_gdb = ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase;
      var tbx_option = ApplicationOptions.GeneralOptions.DefaultToolboxOption;
      var def_tbx = ApplicationOptions.GeneralOptions.CustomDefaultToolbox;
      var create_in_folder = ApplicationOptions.GeneralOptions.ProjectCreateInFolder;
    Set GeneralOptions to Use Custom Settings
      //Set the application to use a custom project, home folder, gdb, and toolbox
      //In each case, the custom _path_ must be set _first_ before
      //setting the "option". This ensures the application remains
      //in a consistent state. This is the same behavior as on the Pro UI.
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.StartupProjectPath))
        ApplicationOptions.GeneralOptions.StartupProjectPath = @"D:\data\usa.aprx";//custom project path first
      ApplicationOptions.GeneralOptions.StartupOption = StartProjectMode.WithDefaultProject;//option to use it second
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.CustomHomeFolder))
        ApplicationOptions.GeneralOptions.CustomHomeFolder = @"D:\home_folder";//custom home folder first
      ApplicationOptions.GeneralOptions.HomeFolderOption = OptionSetting.UseCustom;//option to use it second
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase))
        ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase = @"D:\data\usa.gdb";//custom gdb path first
      ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption = OptionSetting.UseCustom;//option to use it second
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.CustomDefaultToolbox))
        ApplicationOptions.GeneralOptions.CustomDefaultToolbox = @"D:\data\usa.tbx";//custom toolbox path first
      ApplicationOptions.GeneralOptions.DefaultToolboxOption = OptionSetting.UseCustom;//option to use it second
    Set GeneralOptions to Use Defaults
      //Default options can be set regardless of the value of the "companion"
      //path (to a project, folder, gdb, toolbox, etc.). The path value is ignored if
      //the option setting does not use it. This is the same behavior as on the Pro UI.
      ApplicationOptions.GeneralOptions.StartupOption = StartProjectMode.ShowStartPage;
      ApplicationOptions.GeneralOptions.HomeFolderOption = OptionSetting.UseDefault;
      ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption = OptionSetting.UseDefault;
      ApplicationOptions.GeneralOptions.DefaultToolboxOption = OptionSetting.UseDefault;//set default option first
      //path values can (optionally) be set (back) to null if their
      //"companion" option setting is the default option.
      if (ApplicationOptions.GeneralOptions.StartupOption != StartProjectMode.WithDefaultProject)
        ApplicationOptions.GeneralOptions.StartupProjectPath = null;
      if (ApplicationOptions.GeneralOptions.HomeFolderOption == OptionSetting.UseDefault)
        ApplicationOptions.GeneralOptions.CustomHomeFolder = null;
      if (ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption == OptionSetting.UseDefault)
        ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase = null;
      if (ApplicationOptions.GeneralOptions.DefaultToolboxOption == OptionSetting.UseDefault)
        ApplicationOptions.GeneralOptions.CustomDefaultToolbox = null;
    Requirements
