ArcGIS.Desktop.Core Namespace / GeneralOptions Class / StartupProjectPath Property
Example
    Gets and sets the path to a default project (.aprx) to use when the application starts
    Syntax
    Public Property StartupProjectPath As String
    public string StartupProjectPath {get; set;}
    Remarks
    Attempting to set StartupProjectPath to an invalid .aprx path will be ignored.
    Set StartupOption to StartProjectMode.WithDefaultProjectafter setting the StartupProjectPath (to use the StartupProjectPath at start-up). Attempting to set the StartupOption to StartProjectMode.WithDefaultProject before the StartupProjectPath contains a valid .aprx path will be ignored.
    Conversely, attempting to set the StartupProjectPath back to null or empty string will be ignored if StartupOption is currently set to StartProjectMode.WithDefaultProject. The StartupOption must be changed to a different start mode first.
    Example
    Get GeneralOptions
      var startMode = ApplicationOptions.GeneralOptions.StartupOption;
      var aprx_path = ApplicationOptions.GeneralOptions.StartupProjectPath;
      var hf_option = ApplicationOptions.GeneralOptions.HomeFolderOption;
      var folder = ApplicationOptions.GeneralOptions.CustomHomeFolder;
      var gdb_option = ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption;
      var def_gdb = ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase;
      var tbx_option = ApplicationOptions.GeneralOptions.DefaultToolboxOption;
      var def_tbx = ApplicationOptions.GeneralOptions.CustomDefaultToolbox;
      var create_in_folder = ApplicationOptions.GeneralOptions.ProjectCreateInFolder;
    Set GeneralOptions to Use Custom Settings
      //Set the application to use a custom project, home folder, gdb, and toolbox
      //In each case, the custom _path_ must be set _first_ before
      //setting the "option". This ensures the application remains
      //in a consistent state. This is the same behavior as on the Pro UI.
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.StartupProjectPath))
        ApplicationOptions.GeneralOptions.StartupProjectPath = @"D:\data\usa.aprx";//custom project path first
      ApplicationOptions.GeneralOptions.StartupOption = StartProjectMode.WithDefaultProject;//option to use it second
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.CustomHomeFolder))
        ApplicationOptions.GeneralOptions.CustomHomeFolder = @"D:\home_folder";//custom home folder first
      ApplicationOptions.GeneralOptions.HomeFolderOption = OptionSetting.UseCustom;//option to use it second
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase))
        ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase = @"D:\data\usa.gdb";//custom gdb path first
      ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption = OptionSetting.UseCustom;//option to use it second
      if (string.IsNullOrEmpty(ApplicationOptions.GeneralOptions.CustomDefaultToolbox))
        ApplicationOptions.GeneralOptions.CustomDefaultToolbox = @"D:\data\usa.tbx";//custom toolbox path first
      ApplicationOptions.GeneralOptions.DefaultToolboxOption = OptionSetting.UseCustom;//option to use it second
    Set GeneralOptions to Use Defaults
      //Default options can be set regardless of the value of the "companion"
      //path (to a project, folder, gdb, toolbox, etc.). The path value is ignored if
      //the option setting does not use it. This is the same behavior as on the Pro UI.
      ApplicationOptions.GeneralOptions.StartupOption = StartProjectMode.ShowStartPage;
      ApplicationOptions.GeneralOptions.HomeFolderOption = OptionSetting.UseDefault;
      ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption = OptionSetting.UseDefault;
      ApplicationOptions.GeneralOptions.DefaultToolboxOption = OptionSetting.UseDefault;//set default option first
      //path values can (optionally) be set (back) to null if their
      //"companion" option setting is the default option.
      if (ApplicationOptions.GeneralOptions.StartupOption != StartProjectMode.WithDefaultProject)
        ApplicationOptions.GeneralOptions.StartupProjectPath = null;
      if (ApplicationOptions.GeneralOptions.HomeFolderOption == OptionSetting.UseDefault)
        ApplicationOptions.GeneralOptions.CustomHomeFolder = null;
      if (ApplicationOptions.GeneralOptions.DefaultGeodatabaseOption == OptionSetting.UseDefault)
        ApplicationOptions.GeneralOptions.CustomDefaultGeodatabase = null;
      if (ApplicationOptions.GeneralOptions.DefaultToolboxOption == OptionSetting.UseDefault)
        ApplicationOptions.GeneralOptions.CustomDefaultToolbox = null;
    Requirements
