ArcGIS.Desktop.Core Namespace / Item Class / DeleteMetadataContent Method
Example
    DeleteMetadataContent Method (Item)
    Delete certain content from the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub DeleteMetadataContent( _
       ByVal deleteOption As MDDeleteContentOption _
    public void DeleteMetadataContent(
       MDDeleteContentOption deleteOption
    Parameters
    deleteOption
    Exceptions
    ExceptionDescription
    Example
    Item: Delete certain content from the metadata of the current item: DeleteMetadataContent
      Item featureClassWithMetadataItem = ItemFactory.Instance.Create(@"C:\projectBeta\GDBs\regionFive.gdb\SourceFeatureClass");
      //Delete thumbnail content from item's metadata
      featureClassWithMetadataItem.DeleteMetadataContent(MDDeleteContentOption.esriMDDeleteThumbnail);
    Requirements
