ArcGIS.Desktop.Core Namespace / LayoutOptions Class
Members Example
    LayoutOptions Class
    Gets and sets the application layout options.
    Object Model
    LayoutOptions ClassCIMColor ClassCIMColor Class
    Syntax
    Public Class LayoutOptions
    public class LayoutOptions
    Example
    Get LayoutOptions
      var lastToolActive = ApplicationOptions.LayoutOptions.KeepLastToolActive;
      var warnOnSurrounds = ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds;
      //eg <Install_Path>\Resources\LayoutTemplates\en-US
      var gallery_path = ApplicationOptions.LayoutOptions.LayoutTemplatePath;
      var defaultGuideColor = ApplicationOptions.LayoutOptions.DefaultGuideColor;
      //Note: Must be on QueuedTask.Run.
      var guideColor = ApplicationOptions.LayoutOptions.GetGuideColor();
    Set LayoutOptions
      //keep graphic element insert tool active
      ApplicationOptions.LayoutOptions.KeepLastToolActive = true;
      //no warning when deleting a map frame results in other elements being deleted
      ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds = false;
      //path to .pagx files used as templates
      ApplicationOptions.LayoutOptions.LayoutTemplatePath = @"D:\data\layout_templates";
      // set guide color
      ApplicationOptions.LayoutOptions.SetGuideColor(ColorFactory.Instance.RedRGB);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Core.LayoutOptions
    Requirements
