/// <summary> /// Within the specialization of a MapTool, this method handles activation and deactivation of the tool, allowing customization of sketch segment and vertex symbology when /// the tool becomes active. When the tool is activated, this method customizes the appearance of sketch segments and vertices by updating their symbol options. This includes setting colors, widths, marker types, and other visual properties for both segments and regular unselected vertices. /// </summary> protected override async Task OnToolActivateAsync(bool active) { await QueuedTask.Run(() => { //Getting the current symbology options of the segment var segmentOptions = GetSketchSegmentSymbolOptions(); //Modifying the primary and secondary color and the width of the segment symbology options var deepPurple = new CIMRGBColor() { R = 75, G = 0, B = 110 }; segmentOptions.PrimaryColor = deepPurple; segmentOptions.Width = 4; segmentOptions.HasSecondaryColor = true; var pink = new CIMRGBColor() { R = 219, G = 48, B = 130 }; segmentOptions.SecondaryColor = pink; //Creating a new vertex symbol options instance with the values you want var vertexOptions = new VertexSymbolOptions(VertexSymbolType.RegularUnselected); var yellow = new CIMRGBColor() { R = 255, G = 215, B = 0 }; var purple = new CIMRGBColor() { R = 148, G = 0, B = 211 }; vertexOptions.AngleRotation = 45; vertexOptions.Color = yellow; vertexOptions.MarkerType = VertexMarkerType.Star; vertexOptions.OutlineColor = purple; vertexOptions.OutlineWidth = 3; vertexOptions.Size = 5; //Setting the value of the segment symbol options SetSketchSegmentSymbolOptions(segmentOptions); //Setting the value of the vertex symbol options of the regular unselected vertices using the vertexOptions instance created above. SetSketchVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexOptions); }); await base.OnToolActivateAsync(active); }
var options = ApplicationOptions.EditingOptions;
//var options = ApplicationOptions.EditingOptions;
var seg_options = options.GetSegmentSymbolOptions();
//to convert the options to a symbol use
//SymbolFactory. Note: this is approximate....sketch isn't using the
//CIM directly for segments
var layers = new List<CIMSymbolLayer>();
var stroke0 = SymbolFactory.Instance.ConstructStroke(seg_options.PrimaryColor,
seg_options.Width, SimpleLineStyle.Dash);
layers.Add(stroke0);
if (seg_options.HasSecondaryColor)
var stroke1 = SymbolFactory.Instance.ConstructStroke(
seg_options.SecondaryColor, seg_options.Width, SimpleLineStyle.Solid);
layers.Add(stroke1);
//segment symbology only
var sketch_line = new CIMLineSymbol()
SymbolLayers = layers.ToArray()
//change the segment symbol primary color to green and
//width to 1 pt
var segSymbol = options.GetSegmentSymbolOptions();
segSymbol.PrimaryColor = ColorFactory.Instance.GreenRGB;
segSymbol.Width = 1;
//Are these valid?
if (options.CanSetSegmentSymbolOptions(segSymbol))
//apply them
options.SetSegmentSymbolOptions(segSymbol);
var def_seg = options.GetDefaultSegmentSymbolOptions();
options.SetSegmentSymbolOptions(def_seg);
System.Object
ArcGIS.Desktop.Core.SegmentSymbolOptions
