ArcGIS.Desktop.Core Namespace / TextAndGraphicsElementsOptions Class / GetDefaultTextSymbol Method
Example
    Gets the application default text symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public CIMTextSymbol GetDefaultTextSymbol()
    Public Function GetDefaultTextSymbol() As CIMTextSymbol
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get TextAndGraphicsElementsOptions
      await QueuedTask.Run(() =>
        //Get the default font (see also 'SymbolFactory.Instance.DefaultFont')
        var def_font = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultFont();
        System.Diagnostics.Debug.WriteLine(
          $"\r\ndefault font: {def_font.fontName}, {def_font.styleName}");
        //Get the default graphics element symbols - point, line, poly, text
        var ptSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPointSymbol();
        var lineSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultLineSymbol();
        var polySymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPolygonSymbol();
        var textSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultTextSymbol();
    Requirements
