ArcGIS.Desktop.Core Namespace / TextAndGraphicsElementsOptions Class / SetDefaultFont Method / SetDefaultFont(String,String) Method
The font family to set as the default
The default style to use in the font family
Example
    Sets the application default font family name and style. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetDefaultFont(
       string familyName,
       string styleName
    Public Overloads Sub SetDefaultFont( _
       ByVal familyName As String, _
       ByVal styleName As String _
    Parameters
    familyName
    styleName
    Exceptions
    ExceptionDescription
    font not found
    Remarks
    If the input font family name does not exist an System.ArgumentException will be thrown. If the provided style is not found in the input font family the style will default to default font style for the given font family.
    Example
    Get/Set Default Font
      var def_font = SymbolFactory.Instance.DefaultFont;
      System.Diagnostics.Debug.WriteLine($"{def_font.fontName}, styles: {def_font.styleName}");
      //set default font - set through application options
      await QueuedTask.Run(() =>
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
    Requirements
