ArcGIS.Desktop.Core Namespace / VertexSymbolOptions Class / Size Property
Example
    Size Property (VertexSymbolOptions)
    Gets and sets the size (in points). Default value is 5.
    Syntax
    public double Size {get; set;}
    Public Property Size As Double
    Example
    Set Sketch Vertex Symbol Options
      var options = ApplicationOptions.EditingOptions;
      //var options = ApplicationOptions.EditingOptions;
      await QueuedTask.Run(() =>
        //change the regular unselected vertex symbol
        //default is a green, hollow, square, 5pts. Change to
        //Blue outline diamond, 10 pts
        var vertexSymbol = new VertexSymbolOptions(VertexSymbolType.RegularUnselected);
        vertexSymbol.OutlineColor = ColorFactory.Instance.BlueRGB;
        vertexSymbol.MarkerType = VertexMarkerType.Diamond;
        vertexSymbol.Size = 10;
        //Are these valid?
        if (options.CanSetVertexSymbolOptions(
             VertexSymbolType.RegularUnselected, vertexSymbol))
          //apply them
          options.SetVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexSymbol);
    Requirements
