ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / UpdateOverlay Method / UpdateOverlay(MapView,IDisposable,Geometry,CIMSymbolReference,Double,Double) Method
The view containing the overlay.
The IDisposable instance returned from an AddOverlay method call.
The geometry to be used for the update.
The symbol to use for the update.
Map reference scale or -1
Visibility factor for showing the overlay through other objects when obscured in 3D.
Valid range is [0..1], any other value will be treated as 0 (not visible).
    Updates the geometry and symbol for an overlay graphic on the map view.
    Syntax
    Public Overloads Shared Function UpdateOverlay( _
       ByVal mapView As MapView, _
       ByVal disposable As IDisposable, _
       ByVal geometry As Geometry, _
       ByVal symbol As CIMSymbolReference, _
       ByVal referenceScale As Double, _
       ByVal showThrough As Double _
    ) As Boolean
    Parameters
    mapView
    disposable
    geometry
    symbol
    referenceScale
    showThrough
    Return Value
    True if the overlay was updated. False otherwise.
    Requirements
