ArcGIS.Desktop.Reports Namespace / Report Class / AddSubReport Method
The subreport item.
Position to add subreport. If -1, the subreport is added to the end of the report. If 0, the subreport is added to the beginning of the report.
Adjust the size of the subreport to match main report.
Example
    AddSubReport Method
    Adds a subreport to the report. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub AddSubReport( _
       ByVal reportItem As Item, _
       ByVal insertIndex As Integer, _
       ByVal adjustPageSize As Boolean _
    public void AddSubReport(
       Item reportItem,
       int insertIndex,
       bool adjustPageSize
    Parameters
    reportItem
    The subreport item.
    insertIndex
    adjustPageSize
    Exceptions
    ExceptionDescription
    The reportItem is invalid.
    Example
    Add SubReport
      //Note: Call within QueuedTask.Run()
      var mainReport = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(r => r.Name == "USAReports")?.GetReport();
      if (mainReport == null) return;
      //Add sub report
      var vermontReportItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(r => r.Name == "Vermont");
      if (vermontReportItem == null) return;
      Report vermontReport = vermontReportItem.GetReport();
      mainReport.AddSubReport(vermontReportItem, -1, true); //  If -1, the subreport is added to the end of the report.
    Requirements
