ArcGIS.Desktop.Mapping Namespace / StandaloneTableCreationParams Class
Members Example
    Represents an object to initialize and create a standalone table with pre-defined properties such as a definition query.
    Object Model
    StandaloneTableCreationParams ClassAttributedRelationshipClass ClassCIMDataConnection ClassDefinitionQuery ClassItem ClassCIMLayerDocument ClassTable Class
    Syntax
    Public Class StandaloneTableCreationParams
       Inherits MapMemberCreationParams
    public class StandaloneTableCreationParams : MapMemberCreationParams
    Example
    Create a StandaloneTable
        //container can be a map or group layer
        var container = MapView.Active.Map;
        //var container =  MapView.Active.Map.GetLayersAsFlattenedList()
        //                                  .OfType<GroupLayer>().First();
        //Note: Run within a QueuedTask
        //use a local path
        var table = StandaloneTableFactory.Instance.CreateStandaloneTable(
            new Uri(@"C:\Temp\Data\SDK.gdb\EarthquakeDamage", UriKind.Absolute), container);
        //use a URI to a feature service table endpoint
        var table2 = StandaloneTableFactory.Instance.CreateStandaloneTable(
                      new Uri(@"https://bexdog.esri.com/server/rest/services/FeatureServer" + "/2", UriKind.Absolute), container);
        //Use an item
        var item = ItemFactory.Instance.Create(@"C:\Temp\Data\SDK.gdb\ParcelOwners");
        var tableCreationParams = new StandaloneTableCreationParams(item);
        var table3 = StandaloneTableFactory.Instance.CreateStandaloneTable(tableCreationParams, container);
        //use table creation params
        var table_params = new StandaloneTableCreationParams(item)
            DefinitionQuery = new DefinitionQuery(whereClause: "LAND_USE = 3", name: "Landuse")
        var table4 = StandaloneTableFactory.Instance.CreateStandaloneTable(table_params, container);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.BaseCreationParams
          ArcGIS.Desktop.Mapping.MapMemberCreationParams
             ArcGIS.Desktop.Mapping.StandaloneTableCreationParams
    Requirements
