ArcGIS.Desktop.Core Namespace / TextAndGraphicsElementsOptions Class / GetAvailableFonts Method
Example
    GetAvailableFonts Method (TextAndGraphicsElementsOptions)
    Gets the list of available fonts in the application for the Pro session. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Return Value
    A list of tuples where tuple.fontName is the font family name and tuple.fontStyles is a list of available styles for the given font family
    Exceptions
    ExceptionDescription
    Example
    Get All Available Fonts
      //Note: see also SymbolFactory.Instance.GetAvailableFonts() which returns the
      //same list. Use for TextAndGraphicsElementsOptions.GetAvailableFonts() convenience
      //A list of tuples of Font name + associated Font Styles, one tuple per
      //font, is returned
      await QueuedTask.Run(() =>
        var fonts = ApplicationOptions.TextAndGraphicsElementsOptions.GetAvailableFonts();
        StringBuilder sb = new StringBuilder();
        sb.AppendLine("Pro Fonts\r\n============================");
        foreach (var font in fonts)
          var styles = string.Join(",", font.fontStyles);
          sb.AppendLine($"{font.fontName}, [{styles}]");
        System.Diagnostics.Debug.WriteLine(sb.ToString());
    Requirements
