ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / CreateTemplate Method / CreateTemplate(MapMember,CIMEditingTemplate) Method
The map member the new template is to be added to.
The template definition.
Example
    Creates a new template using the specified definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function CreateTemplate( _
       ByVal mapMember As MapMember, _
       ByVal templateDef As CIMEditingTemplate _
    ) As EditingTemplate
    Parameters
    mapMember
    templateDef
    Return Value
    The newly created template. Null if it cannot be created.
    Example
    Create New Table Template using table.CreateTemplate
    // Creates new table templates for the specified standalone table.
    await QueuedTask.Run(() =>
      var table = activeMap.GetStandaloneTablesAsFlattenedList().FirstOrDefault();
      var tableTemplate = table.GetTemplate("Template1");
      var definition = tableTemplate.GetDefinition();
      definition.Description = "New definition";
      definition.Name = "New name";
      //Create new table template using this definition
      table.CreateTemplate(definition);
      //You can also create a new table template using this extension method. You can use this method the same way you use the layer.CreateTemplate method.
      table.CreateTemplate("New template name", "Template description", tags: ["tag 1", "tag 2"]);
    Requirements
