ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructTextSymbol Method / ConstructTextSymbol(String) Method
The font family name of the text symbol to construct.
Example
    Constructs a default text symbol given its font family name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    CIMTextSymbol ConstructTextSymbol(
       string fontFamilyName
    Overloads Function ConstructTextSymbol( _
       ByVal fontFamilyName As String _
    ) As CIMTextSymbol
    Parameters
    fontFamilyName
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Remarks
    If the font family is null or does not exist the current default font family will be assigned. The default color, size, and font style are assigned.
    Example
    Construct a Text Symbol With Options
      await QueuedTask.Run(() =>
        //using the default font
        var textSym1 = SymbolFactory.Instance.ConstructTextSymbol();
        var textSym2 = SymbolFactory.Instance.ConstructTextSymbol(
                           ColorFactory.Instance.BlueRGB, 14);
      //using a specific font
      var textSym3 = SymbolFactory.Instance.ConstructTextSymbol("Arial");
      var textSym4 = SymbolFactory.Instance.ConstructTextSymbol(
                        "Arial", "Narrow Bold");
      //or query available fonts to ensure the font is there
      var all_fonts = SymbolFactory.Instance.GetAvailableFonts();
      var font = all_fonts.FirstOrDefault(f => f.fontName == "Arial");
      if (!string.IsNullOrEmpty(font.fontName))
        var textSym5 = SymbolFactory.Instance.ConstructTextSymbol(font.fontName);
        //or with a font+style
        var textSym6 = SymbolFactory.Instance.ConstructTextSymbol(
                                        font.fontName, font.fontStyles.First());
      //overloads - font + color and size, etc
      var textSym7 = SymbolFactory.Instance.ConstructTextSymbol(
                      ColorFactory.Instance.BlueRGB, 14, "Times New Roman", "Italic");
      //custom symbol - black stroke, red fill
      var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
        SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB),
        SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1));
        var textSym8 = SymbolFactory.Instance.ConstructTextSymbol(
          poly_symbol, 14, "Georgia", "Bold");
    Requirements
