ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructTextSymbol Method / ConstructTextSymbol(CIMPolygonSymbol,Double,String) Method
ArcGIS.Core.CIM.CIMPolygonSymbol
The size of the text symbol to construct.
The font family name of the text symbol to construct.
    Constructs a default text symbol given its polygon symbol, size, and font family name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function ConstructTextSymbol( _
       ByVal symbol As CIMPolygonSymbol, _
       ByVal size As Double, _
       ByVal fontFamilyName As String _
    ) As CIMTextSymbol
    Parameters
    symbol
    size
    fontFamilyName
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Remarks
    If the font family is null or does not exist the current default font family will be assigned. The default font style for the font family will be assigned.
    Requirements
