ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / GetAvailableFonts Method
Example
    GetAvailableFonts Method (SymbolFactory)
    Gets the list of available fonts in the application for the Pro session. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Return Value
    A list of tuples where tuple.fontName is the font family name and tuple.fontStyles is a list of available styles for the given font family
    Exceptions
    ExceptionDescription
    Example
    Get a List of Available Fonts
        //returns a tuple per font: (string fontName, List<string> fontStyles)
        var fonts = SymbolFactory.Instance.GetAvailableFonts();
        foreach (var font in fonts)
            var styles = string.Join(",", font.fontStyles);
            System.Diagnostics.Debug.WriteLine($"{font.fontName}, styles: {styles}");
    Construct a Text Symbol With Options
        //Note: Needs QueuedTask to run
        //using the default font
        var textSym1 = SymbolFactory.Instance.ConstructTextSymbol();
        var textSym2 = SymbolFactory.Instance.ConstructTextSymbol(
                           ColorFactory.Instance.BlueRGB, 14);
        //using a specific font
        var textSym3 = SymbolFactory.Instance.ConstructTextSymbol("Arial");
        var textSym4 = SymbolFactory.Instance.ConstructTextSymbol(
                          "Arial", "Narrow Bold");
        //or query available fonts to ensure the font is there
        var all_fonts = SymbolFactory.Instance.GetAvailableFonts();
        var font = all_fonts.FirstOrDefault(f => f.fontName == "Arial");
        if (!string.IsNullOrEmpty(font.fontName))
            var textSym5 = SymbolFactory.Instance.ConstructTextSymbol(font.fontName);
            //or with a font+style
            var textSym6 = SymbolFactory.Instance.ConstructTextSymbol(
                                            font.fontName, font.fontStyles.First());
        //overloads - font + color and size, etc
        var textSym7 = SymbolFactory.Instance.ConstructTextSymbol(
                        ColorFactory.Instance.BlueRGB, 14, "Times New Roman", "Italic");
        //custom symbol - black stroke, red fill
        var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
          SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB),
          SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1));
        var textSym8 = SymbolFactory.Instance.ConstructTextSymbol(
                poly_symbol, 14, "Georgia", "Bold");
    Requirements
