ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / DefaultFont Property
Example
    DefaultFont Property (SymbolFactory)
    Gets the application default font family name and style. This property must be accessed on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property DefaultFont As ValueTuple(Of String,String)
    public ValueTuple<string,string> DefaultFont {get;}
    Example
    Get/Set Default Font
        var def_font = SymbolFactory.Instance.DefaultFont;
        System.Diagnostics.Debug.WriteLine($"{def_font.fontName}, styles: {def_font.styleName}");
        //set default font - set through application options
        //Note: Must use QueuedTask
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
    Requirements
