ArcGIS.Desktop.Layouts Namespace / LayoutTool Class / HandleKeyUpAsync Method
A LayoutViewKeyEventArgs that contains the event data.
    HandleKeyUpAsync Method (LayoutTool)
    Occurs when the OnToolKeyUp event is handled.
    Syntax
    protected virtual Task HandleKeyUpAsync(
       LayoutViewKeyEventArgs args
    Protected Overridable Function HandleKeyUpAsync( _
       ByVal args As LayoutViewKeyEventArgs _
    ) As Task
    Parameters
    args
    Return Value
    A Task that represents a key up event.
    Remarks
    This method is intended to perform asynchronous operations associated with a key up event. It will be called if you override the OnToolKeyUp virtual method and set the handled property on the LayoutViewKeyEventArgs to true.
    Requirements
