ArcGIS.Desktop.Layouts Namespace / LayoutTool Class / OnToolDoubleClick Method
A LayoutViewMouseButtonEventArgs that contains the event data.
    OnToolDoubleClick Method (LayoutTool)
    Occurs when a mouse button is clicked on the view two or more times.
    Syntax
    Protected Overridable Sub OnToolDoubleClick( _
       ByVal args As LayoutViewMouseButtonEventArgs _
    protected virtual void OnToolDoubleClick(
       LayoutViewMouseButtonEventArgs args
    Parameters
    args
    Remarks
    This method is intended to perform synchronous operations associated with a double-click event. To perform any asynchronous operations set the handled property on the LayoutViewMouseButtonEventArgs to true and override the HandleDoubleClickAsync virtual method.
    Requirements
