ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / TraceManager Class / GetTracer Method / GetTracer(NamedTraceConfiguration) Method
The named trace configuration that the output tracer is associated with.
Example
    Gets a specific Tracer instance based on the namedTraceConfiguration. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    Return Value
    A specific Tracer instance corresponding to the namedTraceConfiguration.
    Exceptions
    ExceptionDescription
    An exception has occurred while creating the tracer.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Trace a utility network using a named trace configuration
      // This routine demonstrates how to perform a trace using a named trace configuration from a utility network
      static void TraceUtilityNetworkUsingNamedTraceConfiguration(UtilityNetwork utilityNetwork, NamedTraceConfiguration namedTraceConfiguration, Element startElement)
        // Get the trace manager from the utility network
        using (TraceManager traceManager = utilityNetwork.GetTraceManager())
          // Get a tracer from the trace manager using the named trace configuration
          Tracer upstreamTracer = traceManager.GetTracer(namedTraceConfiguration);
          // Trace argument holding the trace input parameters
          TraceArgument upstreamTraceArgument = new TraceArgument(namedTraceConfiguration, new List<Element> { startElement });
          // Trace results
          IReadOnlyList<Result> upstreamTraceResults = upstreamTracer.Trace(upstreamTraceArgument);
    Requirements
