ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GeodesicDistance Method / GeodesicDistance(Geometry,Geometry) Method
The first geometry. Cannot be null and its spatial reference cannot be null.
The second geometry. Cannot be null and its spatial reference cannot be null.
Example
    Calculates the geodesic distance between two geometries.
    Syntax
    Overloads Function GeodesicDistance( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Double
    double GeodesicDistance(
       Geometry geometry1,
       Geometry geometry2
    Parameters
    geometry1
    geometry2
    Return Value
    The geodesic distance between the two geometries in meters. If either of the input geometries is empty, then NaN is returned.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null. Or the spatial reference of either geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    Incompatible spatial references between the input geometries.
    Spatial reference of geometry1or geometry2is an image coordinate system.
    Remarks
    Geodesic distance is the shortest distance between two points on the surface of the Earth.
    Example
    Determine geodesic distance between two Geometries
      var point1 = MapPointBuilderEx.CreateMapPoint(-170, 45, SpatialReferences.WGS84);
      var point2 = MapPointBuilderEx.CreateMapPoint(170, 45, SpatialReferences.WGS84);
      var distances_meters = GeometryEngine.Instance.GeodesicDistance(point1, point2);
      // distance is approximately 1572912.2066940258 in meters
      var distance_feet = GeometryEngine.Instance.GeodesicDistance(point1, point2, LinearUnit.Feet);
      // distance is approximately  5160473.11904786 in feet
    Requirements
