ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / ShapePreservingLength Method / ShapePreservingLength(Geometry) Method
The input geometry. Cannot be null and its spatial reference cannot be null.
Example
    Calculates the length of the geometry on the surface of the Earth ellipsoid. This method preserves the shape of the geometry in its coordinate system.
    Syntax
    Overloads Function ShapePreservingLength( _
       ByVal geometry As Geometry _
    ) As Double
    double ShapePreservingLength(
       Geometry geometry
    Parameters
    geometry
    Return Value
    Length of the geometry in meters. If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null or geometry's spatial reference is null.
    The method is not implemented for GeometryBag or Multipatch.
    Geometry is missing a spatial reference.
    Spatial reference of geometryis an image coordinate system.
    Remarks
    This method preserves the shape of the geometry in its coordinate system. In other words, the length will be calculated for the geometry you see in the map. For example, if you have a polyline with only two vertices that represents the equator, the length returned will be the length of the equator.
    Example
    Calculate length of geometry on surface of Earth's ellipsoid - ShapePreservingLength
      // pt
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0, SpatialReferences.WebMercator);
      double len = GeometryEngine.Instance.ShapePreservingLength(pt);          // len = 0
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(1.0, 3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3, 3, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0, 3.0),
      // multipoint
      Multipoint mPt = MultipointBuilderEx.CreateMultipoint(pts);
      len = GeometryEngine.Instance.ShapePreservingLength(mPt);                // len = 0
      // polyline
      polyline = PolylineBuilderEx.CreatePolyline(pts, SpatialReferences.WGS84);
      len = GeometryEngine.Instance.ShapePreservingLength(polyline);
      // polygon
      polygon = PolygonBuilderEx.CreatePolygon(pts, SpatialReferences.WGS84);
      len = GeometryEngine.Instance.ShapePreservingLength(polygon);
        MapPointBuilderEx.CreateMapPoint( -170, 0),
      MapPointBuilderEx.CreateMapPoint( 170, 0)
      ], SpatialReferences.WGS84);
      var length_meters = GeometryEngine.Instance.ShapePreservingLength(polyline); // , LinearUnits.Meters);
      var length_miles = GeometryEngine.Instance.ShapePreservingLength(polyline, LinearUnit.Miles);
      // length_meters - 37848626.869713023
      // length_miles - 23518.046402579574
    Requirements
