ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / EllipticArcBuilderEx Constructor / EllipticArcBuilderEx Constructor(Double,Double,Coordinate2D,Double,SpatialReference)
The angle, measured from a horizontal line through the circular arc's center point, that defines where the arc starts.
The angle which describes the span of the circular arc.
The center point of the embedded circle.
The distance from the center of the embedded circle to the perimeter.
(Optional) The spatial reference of the arc. The default value is null.
Example
    Creates a new instance of the EllipticArcBuilderEx class. The new instance will be a circular arc.
    Syntax
    Public Function New( _
       ByVal startAngle As Double, _
       ByVal centralAngle As Double, _
       ByVal centerPt As Coordinate2D, _
       ByVal radius As Double, _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    startAngle
    centralAngle
    centerPt
    radius
    spatialReference
    Exceptions
    Example
    Construct a Circular Arc - using a center point, angle and radius
      // Construct a circular arc with center point at (0, 0), from angle = 0,
      // central angle = pi/2, radius = 1.
      // Use a builderEx convenience method or use a builderEx constructor.
      SpatialReference sr4326 = SpatialReferences.WGS84;
      Coordinate2D centerPt = new Coordinate2D(0, 0);
      double fromAngle = 0;
      double centralAngle = Math.PI / 2;
      double radius = 1;
      // BuilderEx convenience methods don't need to run on the MCT.
      EllipticArcSegment circularArcBuilder = EllipticArcBuilderEx.CreateCircularArc(fromAngle, centralAngle, centerPt, radius, sr4326);
      // BuilderEx constructors don't need to run on the MCT.
      EllipticArcBuilderEx ellipticArcBuilderEx = new EllipticArcBuilderEx(fromAngle, centralAngle, centerPt, radius, sr4326);
      ellipticArcSegment = ellipticArcBuilderEx.ToSegment();
    Create Ellipse Text Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                            ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
      string text = "Ellipse, ellipse, ellipse";
      GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
    Create Predefined Shape Graphic Element 3
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                            ColorFactory.Instance.GreenRGB, 2.0, SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                       ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical, outline);
      var ge = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
        layout, PredefinedShape.Ellipse, poly.Extent.Center, 0, 0, ellipseSym,
        "New Ellipse2", false, new ElementInfo() { Anchor = Anchor.TopRightCorner });
    Requirements
