ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / QueryCoords Method
The center point of the ellipse.
The start angle in radians measured from the rotated X-axis.
The central angle in radians measuring the span of the arc from startAngle to endAngle. A positive value corresponds to counterclockwise orientation.
The angle in radians by which the ellipse is rotated from the X-axis. A positive value corresponds to counterclockwise rotation.
The length of the semi-major axis.
The length of the semi-minor axis.
    QueryCoords Method (EllipticArcBuilderEx)
    Copies the center point, start angle, central angle, rotation angle, semi-major/semi-minor axes into the method parameters.
    Syntax
    Public Sub QueryCoords( _
       ByRef centerPt As Coordinate2D, _
       ByRef startAngle As Double, _
       ByRef centralAngle As Double, _
       ByRef rotationAngle As Double, _
       ByRef semiMajorAxis As Double, _
       ByRef semiMinorAxis As Double _
    Parameters
    centerPt
    startAngle
    centralAngle
    rotationAngle
    semiMajorAxis
    semiMinorAxis
    Remarks
    The angles are in radians.
    Requirements
