ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / SetCoords Method / SetCoords(Coordinate2D,Double,Double,Double,Double,Double) Method
The center point of the ellipse.
The start angle in radians measured from the rotated X-axis.
The central angle in radians measuring the span of the arc from startAngle to endAngle. A positive value corresponds to counterclockwise orientation.
The angle in radians by which the ellipse is rotated from the X-axis. A positive value corresponds to counterclockwise rotation.
The length of the semi-major axis.
The length of the semi-minor axis.
    Sets the center point, start angle, central angle, rotation angle, semi-major/semi-minor axes.
    Syntax
    Parameters
    centerPt
    startAngle
    centralAngle
    rotationAngle
    semiMajorAxis
    semiMinorAxis
    Exceptions
    ExceptionDescription
    centerPt is empty.
    A double value is NaN.
    Remarks
    The angles are in radians
    Requirements
