ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / MinorMajorRatio Property
    MinorMajorRatio Property (EllipticArcBuilderEx)
    Gets or sets the minor-major ratio.
    Syntax
    public double MinorMajorRatio {get; set;}
    Public Property MinorMajorRatio As Double
    Exceptions
    ExceptionDescription
    The MinorMajorRatio is NaN.
    The absolute value of the MinorMajorRatio is > 1.
    Remarks
    The minor-major ratio is the length of the semi-minor axis to the length of the semi-major axis. In other words, semi-major axis = minor-major ratio * semi-major axis. The absolute value of the minor-major ratio must be <= 1.
    Changing the minor-major ratio may change the start and end points. The IsCircular property may also change since the arc is circular if and only if the minor-major ratio = 1.
    Requirements
