ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / StartAngle Property
Example
    StartAngle Property (EllipticArcBuilderEx)
    Gets or sets the start angle in radians.
    Syntax
    public double StartAngle {get; set;}
    Public Property StartAngle As Double
    Property Value
    A double representing the start angle.
    Exceptions
    ExceptionDescription
    The StartAngle is NaN.
    Remarks
    The start angle is the angle of the line defined by the CenterPoint and the StartPoint. If RotationAngle != 0, then the start angle is relative to the rotated SemiMajorAxis rather than the X-axis. The start angle is is measured in radians and is always between -PI and +PI. Changing the start angle may also change the start point and central angle.
    Example
    Elliptic Arc Builder Properties
      // retrieve the curve's properties
      EllipticArcBuilderEx builder = new EllipticArcBuilderEx(ellipticArcSegment);
      MapPoint startPt = builder.StartPoint;
      MapPoint endPt = builder.EndPoint;
      Coordinate2D centerPt = builder.CenterPoint;
      bool isCircular = builder.IsCircular;
      bool isMinor = builder.IsMinor;
      double startAngle = builder.StartAngle;
      double endAngle = builder.EndAngle;
      double centralAngle = builder.CentralAngle;
      double rotationAngle = builder.RotationAngle;
      ArcOrientation orientation = builder.Orientation;
    Requirements
