ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GeodesicArea Method / GeodesicArea(Geometry) Method
The input geometry. Cannot be null and its spatial reference cannot be null.
Example
    Gets the geodesic area of a geometry.
    Syntax
    Public Overloads Function GeodesicArea( _
       ByVal geometry As Geometry _
    ) As Double
    public double GeodesicArea(
       Geometry geometry
    Parameters
    geometry
    Return Value
    The calculated geodesic area in square meters. If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null or geometry's spatial reference is null.
    The method is not implemented for GeometryBag or Multipatch.
    Spatial reference of geometryis an image coordinate system.
    Example
    Calculate the Geodesic Area of a polygon
      polygon = PolygonBuilderEx.CreatePolygon(
        MapPointBuilderEx.CreateMapPoint(-10018754.1713946, 10018754.1713946),
        MapPointBuilderEx.CreateMapPoint(10018754.1713946, 10018754.1713946),
        MapPointBuilderEx.CreateMapPoint(10018754.1713946, -10018754.1713946),
        MapPointBuilderEx.CreateMapPoint(-10018754.1713946, -10018754.1713946)
      ], SpatialReferences.WebMercator);
      var area = GeometryEngine.Instance.GeodesicArea(polygon);
      // area is close to 255032810857732.31
      area = GeometryEngine.Instance.GeodesicArea(polygon, AreaUnit.SquareKilometers);
      // area is close to 255032810.85953,
    Requirements
