ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GeodesicArea Method / GeodesicArea(Geometry,AreaUnit) Method
The input geometry. Cannot be null and its spatial reference cannot be null.
The unit of the output area. If null, then the area is square meters.
Example
    Gets the geodesic area of a geometry.
    Syntax
    Public Overloads Function GeodesicArea( _
       ByVal geometry As Geometry, _
       ByVal areaUnit As AreaUnit _
    ) As Double
    public double GeodesicArea(
       Geometry geometry,
       AreaUnit areaUnit
    Parameters
    geometry
    areaUnit
    Return Value
    The calculated geodesic area in areaUnit. If areaUnit is null, the geodesic area is in square meters.
    If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null or geometry's spatial reference is null.
    The method is not implemented for GeometryBag or Multipatch.
    Spatial reference of geometryis an image coordinate system.
    Example
    Calculate the Geodesic Area of a polygon
      polygon = PolygonBuilderEx.CreatePolygon(
        MapPointBuilderEx.CreateMapPoint(-10018754.1713946, 10018754.1713946),
        MapPointBuilderEx.CreateMapPoint(10018754.1713946, 10018754.1713946),
        MapPointBuilderEx.CreateMapPoint(10018754.1713946, -10018754.1713946),
        MapPointBuilderEx.CreateMapPoint(-10018754.1713946, -10018754.1713946)
      ], SpatialReferences.WebMercator);
      var area = GeometryEngine.Instance.GeodesicArea(polygon);
      // area is close to 255032810857732.31
      area = GeometryEngine.Instance.GeodesicArea(polygon, AreaUnit.SquareKilometers);
      // area is close to 255032810.85953,
    Requirements
