ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GeodeticDistanceAndAzimuth Method / GeodeticDistanceAndAzimuth(MapPoint,MapPoint,GeodeticCurveType,Double,Double) Method
The first input point. Cannot be null.
The second input point. Cannot be null.
The geodetic curve type determining how the distance is measured.
The azimuth from point1 to point2 in radians.
The azimuth from point2 to point1 in radians.
Example
    Calculates distance and azimuth on the spheroid between two points using the given geodetic curve type.
    Syntax
    Public Overloads Function GeodeticDistanceAndAzimuth( _
       ByVal point1 As MapPoint, _
       ByVal point2 As MapPoint, _
       ByVal curveType As GeodeticCurveType, _
       ByRef azimuth12 As Double, _
       ByRef azimuth21 As Double _
    ) As Double
    public double GeodeticDistanceAndAzimuth(
       MapPoint point1,
       MapPoint point2,
       GeodeticCurveType curveType,
       out double azimuth12,
       out double azimuth21
    Parameters
    point1
    point2
    curveType
    azimuth12
    azimuth21
    Return Value
    Geodetic distance between the two points in meters.
    Exceptions
    ExceptionDescription
    One or both of the input points are null, or both of the geometry spatial references are null.
    The spatial references of point1 and point2 are not equal.
    Spatial reference of point1 or point2 is an image coordinate system.
    Remarks
    If point1 or point2 are empty, then azimuth12 = 0, azimuth21 = 0 and the returned geodetic distance is NaN.
    If one of the spatial references is null and the other is not null and not an image coordinate system, then the non-null spatial reference is used. If both spatial references are null, then an exception is thrown. If both spatial references are not null but not equal, then an exception is thrown. If one of the spatial references is an image coordinate system, then an exception is thrown.
    Example
    Calculate geodetic distance, azimuth between two points
      SpatialReference sr = SpatialReferences.WGS84;
      MapPoint p1 = MapPointBuilderEx.CreateMapPoint(111, 55, sr);
      MapPoint p2 = MapPointBuilderEx.CreateMapPoint(95.5845, 64.2285, sr);
      double distance;
      distance = GeometryEngine.Instance.GeodeticDistanceAndAzimuth(p1, p2, GeodeticCurveType.Geodesic, out double az12, out double az21);
      // distance - 1339728.0303777338
      // az12 - 326.235780421405
      // az21 - 132.87425637913955
      distance = GeometryEngine.Instance.GeodeticDistanceAndAzimuth(p1, p2, GeodeticCurveType.Loxodrome, out az12, out az21);
      // distance - 1342745.9687172563
      // az12 - 319.966400332104
      // az21- 139.96640033210397
      distance = GeometryEngine.Instance.GeodeticDistanceAndAzimuth(p1, p2, GeodeticCurveType.GreatElliptic, out az12, out az21);
      // distance - 1339728.038837946
      // az12 - 326.22479262335418
      // az21 - 132.88558894347742
      MapPoint p3 = MapPointBuilderEx.CreateMapPoint(0, 0, sr);
      MapPoint p4 = MapPointBuilderEx.CreateMapPoint(1, 0, sr);
      distance = GeometryEngine.Instance.GeodeticDistanceAndAzimuth(p3, p4, GeodeticCurveType.Geodesic, out az12, out az21);
      // distance - 111319.49079327342
      // az12 - 90
      // az21 - 270
      distance = GeometryEngine.Instance.GeodeticDistanceAndAzimuth(p3, p4, GeodeticCurveType.Geodesic, LinearUnit.Miles, out az12, out az21);
      // distance - 69.1707247134693
      // az12 - 90
      // az21 - 270
    Requirements
