ArcGIS.Desktop.Framework.Controls Namespace / InfoButton Class
Properties Methods Events
    InfoButton Class Members
    The following tables list the members exposed by InfoButton.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public PropertyGets the rendered height of this element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets the rendered width of this element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a value indicating whether this element can be used as the target of a drag-and-drop operation. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether at least one touch is captured to this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether at least one touch is captured to this element or to any child elements in its visual tree. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether at least one touch is pressed over this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether at least one touch is pressed over this element or any child elements in its visual tree. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a brush that describes the background of a control. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the System.Windows.Data.BindingGroup that is used for the element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a brush that describes the border background of a control. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the border thickness of a control. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets a cached representation of the System.Windows.UIElement. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets when the System.Windows.Controls.Primitives.ButtonBase.Click event occurs. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Public PropertyGets or sets the geometry used to define the outline of the contents of an element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a value indicating whether to clip the content of this element (or content coming from the child elements of this element) to fit into the size of the containing element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets the command to invoke when this button is pressed. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Public PropertyGets a collection of System.Windows.Input.CommandBinding objects associated with this element. A System.Windows.Input.CommandBinding enables command handling for this element, and declares the linkage between a command, its events, and the handlers attached by this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets the parameter to pass to the System.Windows.Controls.Primitives.ButtonBase.Command property. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Public PropertyGets or sets the element on which to raise the specified command. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Public PropertyGets or sets the content of a System.Windows.Controls.ContentControl. (Inherited from System.Windows.Controls.ContentControl)
    Public PropertyGets or sets a composite string that specifies how to format the System.Windows.Controls.ContentControl.Content property if it is displayed as a string. (Inherited from System.Windows.Controls.ContentControl)
    Public PropertyGets or sets the data template used to display the content of the System.Windows.Controls.ContentControl. (Inherited from System.Windows.Controls.ContentControl)
    Public Property Gets or sets a template selector that enables an application writer to provide custom template-selection logic. (Inherited from System.Windows.Controls.ContentControl)
    Public Property Gets or sets the context menu element that should appear whenever the context menu is requested through user interface (UI) from within this element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the cursor that displays when the mouse pointer is over this element. (Inherited from System.Windows.FrameworkElement)
    Public Property Gets or sets the data context for an element when it participates in data binding. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets the System.Windows.DependencyObjectType that wraps the CLR type of this instance. (Inherited from System.Windows.DependencyObject)
    Public PropertyGets the size that this element computed during the measure pass of the layout process. (Inherited from System.Windows.UIElement)
    Public PropertyGets the System.Windows.Threading.Dispatcher this System.Windows.Threading.DispatcherObject is associated with. (Inherited from System.Windows.Threading.DispatcherObject)
    Public PropertyGets or sets the bitmap effect to apply to the System.Windows.UIElement. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets the direction that text and other user interface (UI) elements flow within any parent element that controls their layout. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a value that indicates whether the element can receive focus. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a property that enables customization of appearance, effects, or other style characteristics that will apply to this element when it captures keyboard focus. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the font family of the control. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the font size. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the degree to which a font is condensed or expanded on the screen. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the font style. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the weight or thickness of the specified font. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets a value that indicates whether this System.Windows.FrameworkElement should force the user interface (UI) to render the cursor as declared by the System.Windows.FrameworkElement.Cursor property. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a brush that describes the foreground color. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets a value indicating whether this element has any animated properties. (Inherited from System.Windows.UIElement)
    Public Property Gets or sets the suggested height of the element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the horizontal alignment characteristics applied to this element when it is composed within a parent element, such as a panel or items control. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the horizontal alignment of the control's content. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets the collection of input bindings associated with this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets the context for input used by this System.Windows.FrameworkElement. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets a value indicating whether the computed size and position of child elements in this element's layout are valid. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a value that indicates whether a System.Windows.Controls.Button is a Cancel button. A user can activate the Cancel button by pressing the ESC key. (Inherited from System.Windows.Controls.Button)
    Public PropertyGets or sets a value that indicates whether a System.Windows.Controls.Button is the default button. A user invokes the default button by pressing the ENTER key. (Inherited from System.Windows.Controls.Button)
    Public PropertyGets a value that indicates whether a System.Windows.Controls.Button is the button that is activated when a user presses ENTER. (Inherited from System.Windows.Controls.Button)
    Public PropertyGets or sets a value indicating whether this element is enabled in the user interface (UI). This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that determines whether this element has logical focus. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a value that declares whether this element can possibly be returned as a hit test result from some portion of its rendered content. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether this element has been initialized, either during processing by a XAML processor, or by explicitly having its System.Windows.FrameworkElement.EndInit method called. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets a value indicating whether an input method system, such as an Input Method Editor (IME), is enabled for processing the input to this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value indicating whether this element has keyboard focus. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value indicating whether keyboard focus is anywhere within the element or its visual tree child elements. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether this element has been loaded for presentation. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a value that indicates whether manipulation events are enabled on this System.Windows.UIElement. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value indicating whether the current size returned by layout measure is valid. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value indicating whether the mouse is captured to this element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that determines whether mouse capture is held by this element or by child elements in its visual tree. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether the position of the mouse pointer corresponds to hit test results, which take element compositing into account. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value indicating whether the mouse pointer is located over this element (including child elements in the visual tree). This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether this instance is currently sealed (read-only). (Inherited from System.Windows.DependencyObject)
    Public PropertyGets a value indicating whether the stylus is captured by this element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that determines whether stylus capture is held by this element, or an element within the element bounds and its visual tree. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value that indicates whether the stylus position corresponds to hit test results, which take element compositing into account. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets a value indicating whether the stylus cursor is located over this element (including visual child elements). This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a value that indicates whether a control is included in tab navigation. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets a value indicating whether this element is visible in the user interface (UI). This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets localization/globalization language information that applies to an element. (Inherited from System.Windows.FrameworkElement)
    Public Property Gets or sets a graphics transformation that should apply to this element when layout is performed. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the outer margin of an element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the maximum height constraint of the element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the maximum width constraint of the element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the minimum height constraint of the element. (Inherited from System.Windows.FrameworkElement)
    Public Property Gets or sets the minimum width constraint of the element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the identifying name of the element. The name provides a reference so that code-behind, such as event handler code, can refer to a markup element after it is constructed during processing by a XAML processor. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the opacity factor applied to the entire System.Windows.UIElement when it is rendered in the user interface (UI). This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets an opacity mask, as a System.Windows.Media.Brush implementation that is applied to any alpha-channel masking for the rendered content of this element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a value that indicates whether this element incorporates style properties from theme styles. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the padding inside a control. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets the logical parent element of this element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets (or sets) the final render size of this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets transform information that affects the rendering position of this element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets the center point of any possible render transform declared by System.Windows.UIElement.RenderTransform, relative to the bounds of the element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public Property Gets or sets the locally-defined resource dictionary. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a value that determines whether rendering for this element should use device-specific pixel settings during rendering. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets the style used by this element when it is rendered. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a value that determines the order in which elements receive focus when the user navigates through controls by using the TAB key. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets an arbitrary object value that can be used to store custom information about this element. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets a control template. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets a reference to the template parent of this element. This property is not relevant if the element was not created through a template. (Inherited from System.Windows.FrameworkElement)
    Public Property Gets or sets the tool-tip object that is displayed for this element in the user interface (UI). (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets all touch devices that are captured to this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets all touch devices that are captured to this element or any child elements in its visual tree. (Inherited from System.Windows.UIElement)
    Public PropertyGets all touch devices that are over this element. (Inherited from System.Windows.UIElement)
    Public PropertyGets all touch devices that are over this element or any child elements in its visual tree. (Inherited from System.Windows.UIElement)
    Public PropertyGets the collection of triggers established directly on this element, or in child elements. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the unique identifier (for localization) for this element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public PropertyGets or sets a value that indicates whether layout rounding should be applied to this element's size and position during layout. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the vertical alignment characteristics applied to this element when it is composed within a parent element such as a panel or items control. (Inherited from System.Windows.FrameworkElement)
    Public PropertyGets or sets the vertical alignment of the control's content. (Inherited from System.Windows.Controls.Control)
    Public PropertyGets or sets the user interface (UI) visibility of this element. This is a dependency property. (Inherited from System.Windows.UIElement)
    Public Property Gets or sets the width of the element. (Inherited from System.Windows.FrameworkElement)
    Top
    Protected Properties
     NameDescription
    Protected Internal PropertyGets or sets the key to use to reference the style for this control, when theme styles are used or defined. (Inherited from System.Windows.FrameworkElement)
    Protected Internal PropertyGets a value that indicates whether a control supports scrolling. (Inherited from System.Windows.Controls.Control)
    Protected Internal PropertyGets a value that indicates whether the System.Windows.UIElement has focus. (Inherited from System.Windows.UIElement)
    Protected Internal PropertyGets or sets the scope limits for property value inheritance, resource key lookup, and RelativeSource FindAncestor lookup. (Inherited from System.Windows.FrameworkElement)
    Protected PropertyGets the value of the System.Windows.ContentElement.IsEnabled property. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected Internal Property Gets an enumerator to the content control's logical child elements. (Inherited from System.Windows.Controls.ContentControl)
    Protected PropertyGets a collection of all stylus plug-in (customization) objects associated with this element. (Inherited from System.Windows.UIElement)
    Protected PropertyGets or sets the System.Windows.Media.BitmapScalingMode for the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets a cached representation of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets the number of visual child elements within this element. (Inherited from System.Windows.FrameworkElement)
    Protected Internal PropertyGets or sets the System.Windows.Media.ClearTypeHint that determines how ClearType is rendered in the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the clip region of the System.Windows.Media.Visual as a System.Windows.Media.Geometry value. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the edge mode of the System.Windows.Media.Visual as an System.Windows.Media.EdgeMode value. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the bitmap effect to apply to the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the offset value of the visual object. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the opacity of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the System.Windows.Media.Brush value that represents the opacity mask of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets the visual tree parent of the visual object. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets a clipped scrollable area for the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected Internal PropertyGets or sets the System.Windows.Media.TextHintingMode of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected Internal PropertyGets or sets the System.Windows.Media.TextRenderingMode of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the System.Windows.Media.Transform value for the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the x-coordinate (vertical) guideline collection. (Inherited from System.Windows.Media.Visual)
    Protected PropertyGets or sets the y-coordinate (horizontal) guideline collection. (Inherited from System.Windows.Media.Visual)
    Top
    Public Methods
     NameDescription
    Public MethodOverloaded.  (Inherited from System.Windows.UIElement)
    Public MethodAdds handlers to the specified System.Windows.EventRoute for the current System.Windows.UIElement event handler collection. (Inherited from System.Windows.UIElement)
    Public MethodBuilds the current template's visual tree if necessary, and returns a value that indicates whether the visual tree was rebuilt by this call. (Inherited from System.Windows.FrameworkElement)
    Public MethodPositions child elements and determines a size for a System.Windows.UIElement. Parent elements call this method from their System.Windows.UIElement.ArrangeCore(System.Windows.Rect) implementation (or a WPF framework-level equivalent) to form a recursive layout update. This method constitutes the second pass of a layout update. (Inherited from System.Windows.UIElement)
    Public MethodStarts the initialization process for this element. (Inherited from System.Windows.FrameworkElement)
    Public MethodOverloaded.  (Inherited from System.Windows.FrameworkElement)
    Public MethodAttempts to force capture of the mouse to this element. (Inherited from System.Windows.UIElement)
    Public MethodAttempts to force capture of the stylus to this element. (Inherited from System.Windows.UIElement)
    Public MethodAttempts to force capture of a touch to this element. (Inherited from System.Windows.UIElement)
    Public MethodOverloaded.  (Inherited from System.Windows.DependencyObject)
    Public MethodCoerces the value of the specified dependency property. This is accomplished by invoking any System.Windows.CoerceValueCallback function specified in property metadata for the dependency property as it exists on the calling System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public MethodIndicates that the initialization process for the element is complete. (Inherited from System.Windows.FrameworkElement)
    Public Method (Inherited from System.Windows.DependencyObject)
    Public MethodReturns the common ancestor of two visual objects. (Inherited from System.Windows.Media.Visual)
    Public Method (Inherited from System.Windows.FrameworkElement)
    Public MethodSearches for a resource with the specified key, and throws an exception if the requested resource is not found. (Inherited from System.Windows.FrameworkElement)
    Public MethodAttempts to set focus to this element. (Inherited from System.Windows.UIElement)
    Public MethodReturns the base property value for the specified property on this element, disregarding any possible animated value from a running or stopped animation. (Inherited from System.Windows.UIElement)
    Public MethodReturns the System.Windows.Data.BindingExpression that represents the binding on the specified property. (Inherited from System.Windows.FrameworkElement)
    Public MethodGets a hash code for this System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public MethodCreates a specialized enumerator for determining which dependency properties have locally set values on this System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public MethodReturns the current effective value of a dependency property on this instance of a System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public Method (Inherited from System.Windows.UIElement)
    Public MethodInvalidates the arrange state (layout) for the element. After the invalidation, the element will have its layout updated, which will occur asynchronously unless subsequently forced by System.Windows.UIElement.UpdateLayout. (Inherited from System.Windows.UIElement)
    Public MethodInvalidates the measurement state (layout) for the element. (Inherited from System.Windows.UIElement)
    Public MethodInvalidates the rendering of the element, and forces a complete new layout pass. System.Windows.UIElement.OnRender(System.Windows.Media.DrawingContext) is called after the layout cycle is completed. (Inherited from System.Windows.UIElement)
    Public MethodDetermines whether the visual object is an ancestor of the descendant visual object. (Inherited from System.Windows.Media.Visual)
    Public MethodDetermines whether the visual object is a descendant of the ancestor visual object. (Inherited from System.Windows.Media.Visual)
    Public MethodUpdates the System.Windows.UIElement.DesiredSize of a System.Windows.UIElement. Parent elements call this method from their own System.Windows.UIElement.MeasureCore(System.Windows.Size) implementations to form a recursive layout update. Calling this method constitutes the first pass (the "Measure" pass) of a layout update. (Inherited from System.Windows.UIElement)
    Public MethodMoves the keyboard focus away from this element and to another element in a provided traversal direction. (Inherited from System.Windows.FrameworkElement)
    Public MethodConverts a System.Windows.Point in screen coordinates into a System.Windows.Point that represents the current coordinate system of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Public MethodConverts a System.Windows.Point that represents the current coordinate system of the System.Windows.Media.Visual into a System.Windows.Point in screen coordinates. (Inherited from System.Windows.Media.Visual)
    Public MethodDetermines the next element that would receive focus relative to this element for a provided focus movement direction, but does not actually move the focus. (Inherited from System.Windows.FrameworkElement)
    Public MethodReturns the local value of a dependency property, if it exists. (Inherited from System.Windows.DependencyObject)
    Public MethodProvides an accessor that simplifies access to the System.Windows.NameScope registration method. (Inherited from System.Windows.FrameworkElement)
    Public MethodReleases all captured touch devices from this element. (Inherited from System.Windows.UIElement)
    Public MethodReleases the mouse capture, if this element held the capture. (Inherited from System.Windows.UIElement)
    Public MethodReleases the stylus device capture, if this element held the capture. (Inherited from System.Windows.UIElement)
    Public MethodAttempts to release the specified touch device from this element. (Inherited from System.Windows.UIElement)
    Public MethodSearches for a resource with the specified name and sets up a resource reference to it for the specified property. (Inherited from System.Windows.FrameworkElement)
    Public MethodReturns the string representation of a System.Windows.Controls.Control object. (Inherited from System.Windows.Controls.Control)
    Public MethodOverloaded.  (Inherited from System.Windows.Media.Visual)
    Public MethodReturns a transform that can be used to transform coordinates from the System.Windows.Media.Visual to the specified visual object descendant. (Inherited from System.Windows.Media.Visual)
    Public MethodReturns a transform that can be used to transform coordinates from the System.Windows.Media.Visual to the specified visual object. (Inherited from System.Windows.Media.Visual)
    Public MethodTranslates a point relative to this element to coordinates that are relative to the specified element. (Inherited from System.Windows.UIElement)
    Public MethodSearches for a resource with the specified key, and returns that resource if found. (Inherited from System.Windows.FrameworkElement)
    Public MethodSimplifies access to the System.Windows.NameScope de-registration method. (Inherited from System.Windows.FrameworkElement)
    Public MethodReapplies the default style to the current System.Windows.FrameworkElement. (Inherited from System.Windows.FrameworkElement)
    Public MethodEnsures that all visual child elements of this element are properly updated for layout. (Inherited from System.Windows.UIElement)
    Top
    Protected Methods
     NameDescription
    Protected MethodAdds a specified object as the child of a System.Windows.Controls.ContentControl. (Inherited from System.Windows.Controls.ContentControl)
    Protected Internal MethodAdds the provided object to the logical tree of this element. (Inherited from System.Windows.FrameworkElement)
    Protected MethodAdds a specified text string to a System.Windows.Controls.ContentControl. (Inherited from System.Windows.Controls.ContentControl)
    Protected MethodDefines the parent-child relationship between two visuals. (Inherited from System.Windows.Media.Visual)
    Protected MethodImplements System.Windows.UIElement.ArrangeCore(System.Windows.Rect) (defined as virtual in System.Windows.UIElement) and seals the implementation. (Inherited from System.Windows.FrameworkElement)
    Protected MethodCalled to arrange and size the content of a System.Windows.Controls.Control object. (Inherited from System.Windows.Controls.Control)
    Protected MethodReturns a geometry for a clipping mask. The mask applies if the layout system attempts to arrange an element that is larger than the available display space. (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodReturns the named element in the visual tree of an instantiated System.Windows.Controls.ControlTemplate. (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodReturns an alternative logical parent for this element if there is no visual parent. (Inherited from System.Windows.FrameworkElement)
    Protected MethodOverrides System.Windows.Media.Visual.GetVisualChild(System.Int32), and returns a child at the specified index from a collection of child elements. (Inherited from System.Windows.FrameworkElement)
    Protected MethodOverloaded.  (Inherited from System.Windows.UIElement)
    Protected MethodImplements basic measure-pass layout system behavior for System.Windows.FrameworkElement. (Inherited from System.Windows.FrameworkElement)
    Protected MethodCalled to remeasure a control. (Inherited from System.Windows.Controls.Control)
    Protected MethodResponds when the System.Windows.Controls.AccessText.AccessKey for this control is called. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodSupports layout behavior when a child element is resized. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when a System.Windows.Controls.Button is clicked. (Inherited from System.Windows.Controls.Button)
    Protected Method (Inherited from System.Windows.Controls.ContentControl)
    Protected MethodInvoked whenever an unhandled System.Windows.FrameworkElement.ContextMenuClosing routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked whenever an unhandled System.Windows.FrameworkElement.ContextMenuOpening routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodCreates an appropriate System.Windows.Automation.Peers.ButtonAutomationPeer for this control as part of the WPF infrastructure. (Inherited from System.Windows.Controls.Button)
    Protected MethodCalled when the DPI at which this View is rendered changes. (Inherited from System.Windows.Media.Visual)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.DragEnter attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.DragLeave attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.DragOver attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.GiveFeedback attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever an unhandled System.Windows.UIElement.GotFocus event reaches this element in its route. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.GotKeyboardFocus attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.GotMouseCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.GotStylusCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.GotTouchCapture routed event that occurs when a touch is captured to this element. (Inherited from System.Windows.UIElement)
    Protected MethodRaises the System.Windows.FrameworkElement.Initialized event. This method is invoked whenever System.Windows.FrameworkElement.IsInitialized is set to %[LangWord]true %internally. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsKeyboardFocusedChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked just before the System.Windows.UIElement.IsKeyboardFocusWithinChanged event is raised by this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsMouseCapturedChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsMouseCaptureWithinChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsMouseDirectlyOverChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected Method (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsStylusCapturedChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsStylusCaptureWithinChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsStylusDirectlyOverChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.KeyDown routed event that occurs when the user presses a key while this control has focus. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodProvides class handling for the System.Windows.UIElement.KeyUp routed event that occurs when the user releases a key while this control has focus. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodRaises the System.Windows.UIElement.LostFocus routed event by using the event data that is provided. (Inherited from System.Windows.UIElement)
    Protected Method Called when an element loses keyboard focus. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodProvides class handling for the System.Windows.UIElement.LostMouseCapture routed event that occurs when this control is no longer receiving mouse event messages. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.LostStylusCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.LostTouchCapture routed event that occurs when this element loses a touch capture. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationBoundaryFeedback event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationCompleted event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationDelta event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationInertiaStarting event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationStarted event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.ManipulationStarting routed event that occurs when the manipulation processor is first created. (Inherited from System.Windows.UIElement)
    Protected MethodRaises the System.Windows.Controls.Control.MouseDoubleClick routed event. (Inherited from System.Windows.Controls.Control)
    Protected MethodProvides class handling for the System.Windows.UIElement.MouseLeftButtonDown routed event that occurs when the left mouse button is pressed while the mouse pointer is over this control. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodProvides class handling for the System.Windows.UIElement.MouseLeftButtonUp routed event that occurs when the left mouse button is released while the mouse pointer is over this control. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodProvides class handling for the System.Windows.UIElement.MouseMove routed event that occurs when the mouse pointer moves while over this element. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.MouseRightButtonDown routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.MouseRightButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseWheel attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDragEnter attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDragLeave attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDragOver attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDrop attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewGiveFeedback attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.PreviewGotKeyboardFocus attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.PreviewKeyDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.PreviewKeyUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodRaises the System.Windows.Controls.Control.PreviewMouseDoubleClick routed event. (Inherited from System.Windows.Controls.Control)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseDown attached routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseLeftButtonDown routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseLeftButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseRightButtonDown routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseRightButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseWheel attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewQueryContinueDrag attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusButtonDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusButtonUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusInAirMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusInRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusOutOfRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusSystemGesture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.TextCompositionManager.PreviewTextInput attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.PreviewTouchDown routed event that occurs when a touch presses this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.PreviewTouchMove routed event that occurs when a touch moves while inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.PreviewTouchUp routed event that occurs when a touch is released inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever the effective value of any dependency property on this System.Windows.FrameworkElement has been updated. The specific dependency property that changed is reported in the arguments parameter. Overrides System.Windows.DependencyObject.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs). (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.QueryContinueDrag attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.QueryCursor attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodWhen overridden in a derived class, participates in rendering operations that are directed by the layout system. The rendering instructions for this element are not used directly when this method is invoked, and are instead preserved for later asynchronous use by layout and drawing. (Inherited from System.Windows.UIElement)
    Protected Internal Method Called when the rendered size of a control changes. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Protected Internal Method (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusButtonDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusButtonUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusEnter attached event is raised by this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusInAirMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusInRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusLeave attached event is raised by this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusOutOfRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusSystemGesture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected Method (Inherited from System.Windows.Controls.Control)
    Protected MethodInvoked when an unhandled System.Windows.Input.TextCompositionManager.TextInput attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever an unhandled System.Windows.FrameworkElement.ToolTipClosing routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked whenever the System.Windows.FrameworkElement.ToolTipOpening routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchDown routed event that occurs when a touch presses inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchEnter routed event that occurs when a touch moves from outside to inside the bounds of this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchLeave routed event that occurs when a touch moves from inside to outside the bounds of this System.Windows.UIElement. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchMove routed event that occurs when a touch moves while inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchUp routed event that occurs when a touch is released inside this element. (Inherited from System.Windows.UIElement)
    Protected Internal MethodCalled when the System.Windows.Media.VisualCollection of the visual object is modified. (Inherited from System.Windows.Media.Visual)
    Protected Internal MethodInvoked when the parent of this element in the visual tree is changed. Overrides System.Windows.UIElement.OnVisualParentChanged(System.Windows.DependencyObject). (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodSupports incremental layout implementations in specialized subclasses of System.Windows.FrameworkElement. System.Windows.FrameworkElement.ParentLayoutInvalidated(System.Windows.UIElement) is invoked when a child element has invalidated a property that is marked in metadata as affecting the parent's measure or arrange passes during layout. (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodRemoves the provided object from this element's logical tree. System.Windows.FrameworkElement updates the affected logical tree parent pointers to keep in sync with this deletion. (Inherited from System.Windows.FrameworkElement)
    Protected MethodRemoves the parent-child relationship between two visuals. (Inherited from System.Windows.Media.Visual)
    Protected Internal MethodReturns a value that indicates whether serialization processes should serialize the value for the provided dependency property. (Inherited from System.Windows.DependencyObject)
    Top
    Public Events
     NameDescription
    Public EventOccurs when a System.Windows.Controls.Button is clicked. (Inherited from System.Windows.Controls.Primitives.ButtonBase)
    Public EventOccurs just before any context menu on the element is closed. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when any context menu on the element is opened. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when the data context for this element changes. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when the input system reports an underlying drag event with this element as the drag target. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the input system reports an underlying drag event with this element as the drag origin. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the input system reports an underlying drag event with this element as the potential drop target. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the input system reports an underlying drop event with this element as the drop target. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.Focusable property changes. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the input system reports an underlying drag-and-drop event that involves this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element gets logical focus. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the keyboard is focused on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element captures the mouse. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element captures the stylus. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a touch is captured to this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this System.Windows.FrameworkElement is initialized. This event coincides with cases where the value of the System.Windows.FrameworkElement.IsInitialized property changes from false (or undefined) to true. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsEnabled property on this element changes. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsHitTestVisible dependency property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsKeyboardFocused property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsKeyboardFocusWithinChanged property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsMouseCaptured property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsMouseCaptureWithinProperty changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsMouseDirectlyOver property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsStylusCaptured property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsStylusCaptureWithin property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsStylusDirectlyOver property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the value of the System.Windows.UIElement.IsVisible property changes on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a key is pressed while focus is on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a key is released while focus is on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the layout of the various visual elements associated with the current System.Windows.Threading.Dispatcher changes. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the element is laid out, rendered, and ready for interaction. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when this element loses logical focus. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the keyboard is no longer focused on this element,. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element loses mouse capture. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element loses stylus capture. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element loses a touch capture. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the manipulation encounters a boundary. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a manipulation and inertia on the System.Windows.UIElement object is complete. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the input device changes position during a manipulation. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the input device loses contact with the System.Windows.UIElement object during a manipulation and inertia begins. (Inherited from System.Windows.UIElement)
    Public EventOccurs when an input device begins a manipulation on the System.Windows.UIElement object. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the manipulation processor is first created. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a mouse button is clicked two or more times. (Inherited from System.Windows.Controls.Control)
    Public EventOccurs when any mouse button is pressed while the pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the mouse pointer enters the bounds of this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the mouse pointer leaves the bounds of this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the left mouse button is pressed while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the left mouse button is released while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the mouse pointer moves while over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the right mouse button is pressed while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the right mouse button is released while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when any mouse button is released over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the user rotates the mouse wheel while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a drag-and-drop operation is started. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the keyboard is no longer focused on this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a user clicks the mouse button two or more times. (Inherited from System.Windows.Controls.Control)
    Public EventOccurs when the mouse pointer moves while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when any mouse button is released while the mouse pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when there is a change in the keyboard or mouse button state during a drag-and-drop operation. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus button is pressed while the pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus button is released while the pointer is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus touches the digitizer while it is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus moves over an element without actually touching the digitizer. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus is close enough to the digitizer to be detected, while over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus moves while over the element. The stylus must move while being detected by the digitizer to raise this event, otherwise, System.Windows.UIElement.PreviewStylusInAirMove is raised instead. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus is too far from the digitizer to be detected. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a user performs one of several stylus gestures. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the user raises the stylus off the digitizer while the stylus is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when this element gets text in a device-independent manner. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a finger touches the screen while the finger is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a finger moves on the screen while the finger is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a finger is raised off of the screen while the finger is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the cursor is requested to display. This event is raised on an element each time that the mouse pointer moves to a new location, which means the cursor object might need to be changed based on its new position. (Inherited from System.Windows.UIElement)
    Public EventOccurs when System.Windows.FrameworkElement.BringIntoView(System.Windows.Rect) is called on this element. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when either the System.Windows.FrameworkElement.ActualHeight or the System.Windows.FrameworkElement.ActualWidth properties change value on this element. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when the source value changes for any existing property binding on this element. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when the stylus touches the digitizer while the stylus is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus enters the bounds of this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus leaves the bounds of the element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus moves over this element. The stylus must move while on the digitizer to raise this event. Otherwise, System.Windows.UIElement.StylusInAirMove is raised instead. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the stylus is too far from the digitizer to be detected, while over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the user raises the stylus off the digitizer while it is over this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the target value changes for any property binding on this element. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs just before any tooltip on the element is closed. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when any tooltip on the element is opened. (Inherited from System.Windows.FrameworkElement)
    Public EventOccurs when a touch moves from outside to inside the bounds of this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when a touch moves from inside to outside the bounds of this element. (Inherited from System.Windows.UIElement)
    Public EventOccurs when the element is removed from within an element tree of loaded elements. (Inherited from System.Windows.FrameworkElement)
    Top
