ArcGIS.Core.Data Namespace / HistoricalVersion Class
Members Example
    Represents a historical version in a Geodatabase.
    Object Model
    HistoricalVersion ClassGeodatabase Class
    Syntax
    Public NotInheritable Class HistoricalVersion
       Inherits VersionBase
       Implements System.IDisposable
    public sealed class HistoricalVersion : VersionBase, System.IDisposable
    Example
    Creating a Historical version
      // Must be called within QueuedTask.Run
      HistoricalVersion CreateHistoricalVersion(Geodatabase geodatabase, string versionName)
        using (VersionManager versionManager = geodatabase.GetVersionManager())
          HistoricalVersionDescription historicalVersionDescription =
            new HistoricalVersionDescription(versionName, DateTime.Now);
          HistoricalVersion historicalVersion =
            versionManager.CreateHistoricalVersion(historicalVersionDescription);
          return historicalVersion;
    Switching between versions
      void ChangeVersions(Geodatabase geodatabase, string toVersionName)
          VersionBaseType versionBaseType = versionManager.GetCurrentVersionBaseType();
          if (versionBaseType == VersionBaseType.Version)
            Version fromVersion = versionManager.GetCurrentVersion();
            Version toVersion = versionManager.GetVersion(toVersionName);
            // Switch between versions
            MapView.Active.Map.ChangeVersion(fromVersion, toVersion);
          if (versionBaseType == VersionBaseType.HistoricalVersion)
            HistoricalVersion fromHistoricalVersion = versionManager.GetCurrentHistoricalVersion();
            HistoricalVersion toHistoricalVersion = versionManager.GetHistoricalVersion(toVersionName);
            // Switch between historical versions
            MapView.Active.Map.ChangeVersion(fromHistoricalVersion, toHistoricalVersion);
          // Switch from HistoricalVersion to Version and vice-versa
          // MapView.Active.Map.ChangeVersion(fromHistoricalVersion, toVersion);
          // MapView.Active.Map.ChangeVersion(fromVersion, toHistoricalVersion);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.VersionBase
             ArcGIS.Core.Data.HistoricalVersion
    Requirements
