Public NotInheritable Class PostOptions
public sealed class PostOptions
// Must be called within QueuedTask.Run
void ReconcileAndPost(Geodatabase geodatabase)
// Get a reference to our version and our parent
if (geodatabase.IsVersioningSupported())
using (VersionManager versionManager = geodatabase.GetVersionManager())
using (Version currentVersion = versionManager.GetCurrentVersion())
using (Version parentVersion = currentVersion.GetParent())
// Create a ReconcileOptions object
ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
if (!reconcileResult.HasConflicts)
//No conflicts, perform the post
PostOptions postOptions = new PostOptions(parentVersion);
//var postOptions = new PostOptions(); for default version
postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
// Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
// currentVersion.Post(postOptions);
currentVersion.Reconcile(reconcileOptions, postOptions);
void ReconcileAndPost2(Geodatabase geodatabase)
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions, postOptions);
if (reconcileResult.HasConflicts)
//TODO resolve conflicts
System.Object
ArcGIS.Core.Data.PostOptions
